I am going to do a compression check soon to see if valves are seating at TDC. Tonight I just played around with VCDS a bunch and ran through every read out I could find. Today driving home from work, it ran great, and then proceeded to mis and lose power later on, and was missing while i was doing the testing. I have checked every connector on the engine, but need to check all grounds (seems that there are 2 or 3 at least), and need to check if sensors are plugged properly on transmission too (can’t remember if there are 1 or 2 sensors on tranny). Probably good to note, I didn’t touch the mechanical adjusters during the timing job, and left everything locked.
Below is the printout from the vcds blocks that i cycled through and logged, a few of them i logged several times to get a sort of average of what is actually taking place, please chime in about some of the data, I am trying to figure out how to interpret it properly now:
Address 01: Engine (8E0 910 560 G)
21:14:17 Group 091: Camshaft Adjustment (Bank 1 Intake)
0 /min Engine Speed (G28)
5.1 % Cam. Adjustment Intake Bank 1
0.0°KW Cam. Adjustment Intake B1 (spec.)
0.0°KW Cam. Adjustment Intake B1 (act.)
21:14:17 Group 092: Camshaft Adjustment (Bank 2 Intake)
0.0°KW Cam. Adjustment Intake B2 (spec.)
0.0°KW Cam. Adjustment Intake B2 (act.)
21:14:17 Group 093: Camshaft Adjustment Adaptation
-2.0°KW Phase Position Bank 1 Intake
-16.0°KW Phase Position Bank 2 Intake
21:15:02 Group 091: Camshaft Adjustment (Bank 1 Intake)
760 /min Engine Speed (G28)
45.1 % Cam. Adjustment Intake Bank 1
15.0°KW Cam. Adjustment Intake B1 (spec.)
13.5°KW Cam. Adjustment Intake B1 (act.)
21:15:02 Group 092: Camshaft Adjustment (Bank 2 Intake)
46.3 % Cam. Adjustment Intake Bank 1
15.0°KW Cam. Adjustment Intake B2 (spec.)
13.5°KW Cam. Adjustment Intake B2 (act.)
21:15:02 Group 093: Camshaft Adjustment Adaptation
21:15:28 Group 091: Camshaft Adjustment (Bank 1 Intake)
48.2 % Cam. Adjustment Intake Bank 1
12.0°KW Cam. Adjustment Intake B1 (spec.)
11.5°KW Cam. Adjustment Intake B1 (act.)
21:15:28 Group 092: Camshaft Adjustment (Bank 2 Intake)
45.9 % Cam. Adjustment Intake Bank 1
12.0°KW Cam. Adjustment Intake B2 (spec.)
11.0°KW Cam. Adjustment Intake B2 (act.)
21:15:28 Group 094: Camshaft Adjustment (Intake)
13.0°KW Cam. Adjustment Intake B2 (act.)
Test ON Cam. Adj. Test Bank 1 Intake
Test ON Cam. Adj. Test Bank 2 Intake
21:16:12 Group 011: Iginition
102.0°C Coolant Temperature (G62)
68.0°C Intake Air Temperature (G42)
11.3 °BTDC Ignition Timing Angle
21:16:12 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
0 Misfire Counter Cylinder 1
0 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
Enabled Misfire Recognition
21:16:12 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
0 Misfire Counter Cylinder 4
273 Misfire Counter Cylinder 5
1 Misfire Counter Cylinder 6
21:17:00 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
21:17:00 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
161 Misfire Counter Cylinder 5
4 Misfire Counter Cylinder 6
21:17:00 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
75 Misfire Counter Cylinder 7
1 Misfire Counter Cylinder 8
21:17:15 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
21:17:15 Group 016: Ignition (Misfire Recognition - Cylinder 4-6)
224 Misfire Counter Cylinder 5
5 Misfire Counter Cylinder 6
21:17:15 Group 017: Ignition (Misfire Recognition - Cylinder 7-8)
100 Misfire Counter Cylinder 7
4 Misfire Counter Cylinder 8
