Since so many of us are opening their IM and reporting broken intake flaps (even with the updated part number) has anyone tried to convince Audi to make just the intake flap a replacement part instead of the entire IM? I would prefer that to hold me over until JHM comes out with an upgrade. (besides, I can’t seem to find the old flaps to do the epoxy mod)
It seems this is least Audi can do after leaving us with this whole carbon clean mess.
To be honest one would think if we got a consolidated document with the amount of broken IM and IM flappers with research and all signed and provided our invoice that Audi should warranty the part ever time installed for more than 12 months. This is similar to the driveshaft bushing that goes on just above every cayenne s and up trim levels. Porsche sells the entire driveshaft instead of the bushing only…so I paid 400 to upgrade from rubber to a very strong material which has been bullet proof for 400 dollars vs 1000+ for a new driveshaft and shitty rubber bushing. I think there was a a successful class action or at least traction on the cayenne issue driven by a few owners, I’m sure you could do the same here.
Remember there are probably only 4-7k of these cars left in NA inclusive of s6 and s8 so not sure how much attention Audi will give us. Now if you include world wide sales and convince those owners (should be easy minus language barriers) to participate you may be able to get somewhere
Your best bet is send a bunch of broken IM to JHM and see if they might be able to accelerate heir upgraded if that’s even on the table. Problem is the part works and does its job reasonably well. it just has too many points of failure and not durable enough. It becomes one of those things you check like carbon clean every year and a half or year if your anal like me
Yes, only catback. I really am fighting doing headers. I know it would wake the car up completely, but if I don’t go step by step we will never really know what mods do what. These few parts really wake the car up and the JHM tune is going to be the game changer that ties it all in.
I think Audi has moved on from the S6 and S8 motors enough were they wouldn’t even be able to help. At this point our best choice is going to be the aftermarket option.
Now back to the performance parts of the build. Last time we talked about the JHM intake spacers and their ability to help keep the 5.2 V10 heat issues in check. While the spacers are helpful at keeping the motor cooler and more efficient the motor could also benefit from shedding some of that unnecessary weight strapped to the front end of the crankshaft.
So what your saying is that I need that crank pulley for my S5!?
I was concerned that reducing the weight by so much is going to displace that force elsewhere…on some other rotating / moving part up or down the line. But what CV is saying that it is safe and in fact even better. Therefore that force/energy must being going to the wheels ;D!
You need a crank pulley for your S5. The stock crank pulley has a rubber diaphram inside that is there for hryomonic ballence. But due to the fact that the rubber diaphram is usually destryed on older crank pulleys people are not getting any use out of itanyways. That and in the V10 cars they have a huge fluid dampener on the car in the Tq converter so its kinda redundent. As for the S5 you have that huge flywheel that would absorb most of the vibration. The JHM crank pulleys are perfictly ballanced so you get no vibration from ballance issues.
when you say front end needs to be removed to replace the pulley, do you mean just the bumper? Or is their other parts in the way behind that that need to be removed? I would be interested in the crank pulley and changing the belt too while there. That belt is just the ancillary drive belt i guess and these v10’s have a timing chain?
i think i need to do carbon clean, IM spacers and this LW pulley
To do the crank pulley you need to remove the bumper and front core support. Its not too bad of a job. The core support us just behind the bumper it holds the ac condencer and the raidator. Its a great time to flush the coolant.
It makes getting the pulley and the accesory belt on much eaiser.
The Alternator is run off the belt that runs off the crank. The AC and the powersteering are driven off the back of the motor on the timing system.
If you want I can make a post showing how most of that stuff works but it will be on a 4.2 V8 as they are the exact same less two cylinders.
Thanks, If you guys don’t see something that you would like to know about please feel free to ask or post. Keep an eye out for more
Thank you. I think the real question here is, where would the S6/S8 be without out you?
You’re so right. I know, I will speed this along so I can get to that part. Sorry for the gap in posts. When you don’t see posting on my part I am making headway… Or I’m trying to, I promise.
Buddyboy, yes the bumper and core support need to come off as Justin mentioned. While it is an extra step, if you’re doing a carbon clean or full maintenance it’s a great time to pull the front end off to do the accessory belt the coolant flush the crank pulley and with the front end off the carbon clean and spacer install, is a bit easier to do as well.
GIVE ME A BRAKE… Next phase in the performance journey, was to replace my squeaking worn out brakes.
There are several options when it comes to just replacing the OEM rotors. For me, I’ve seen lots of guys go the cheap option and you get what you pay for. Cheap rotors tend to use cheap material that wears out quicker and doesn’t seem to offset the cost in the long run.
For me, I really want to bring out the supercar in my super car. So, the search for performance rotors started and as usual as most of you know there was nothing. So, I called the guys at JHM and asked what they could do. They have performance rotors for just about every other platform why not us. The S8 and S6 front rotors are the same on our cars so its like one big market.
I wanted a lighter more performance oriented rotor that would help drop some rotational weight while pulling out the heat and helping with pad life. Heck, if the Lambo gets performance rotors, that dissipate heat and weigh less, why don’t we right?
BOOM I saved 30lbs of not just weight but rotational weight. That’s a 15lb weight reduction EACH SIDE, while adding a huge drop in breaking temps. That’s more than some light weight rims offer and at a fraction of the cost of lightweight rims.
The added great part is way-way down the line when it comes time to replace the rotors again, you just need to order the rings. Ording the rings will save you quite a bit of money. The rotors cost a bit more due to being two piece and being that their performance rotors. Being two piece has several advantages if you really want to track the S6 you can just get an extra set of rings for the track like lots of the road race guys like to do.
I’m not a huge cosmetic guy but even these OEM rotors look underwhelming.
The other thing l didn’t like about the stock rotors was the fact that the rotor was just a little bigger than the pad surface needed to be. So, this resulted in my rotor having a huge lip on it from where the pads had worn away the material. It made getting the heavy OEM rotors out quite a chore.
Now putting on the JHM rotors. Very easy a straight forward job. The addition of the slotted feature that comes with the JHM rotors is not just great to help in braking performance, but I think it looks nice as well.
To me, it’s hard to beat adding performance while doing maintenance. Nothing is real exciting about doing a brake job, except when you know you’re dropping weight, adding performance and helping make things look just a little better at the same time. It’s a win win win.
That was a fun night hanging out and getting those brakes fitted CV. Don’t forget to mention the trick to getting the rear caliper brake pistons loosened up enough to fit over the rotors
