You must be new to AR. . . threads rarely stay on track here lol. The toughest part of AR is remember what thread you read a certain bit of interesting info on, because it’s rarely related to the thread title.
All in good fun though, this thread should be a good info source and appreciate your work.
I’ve seen 2.0t results all over the board. How can you say what one turbocharger can do more than the other? If the ko4 is bigger how much bigger is it? The acceleration results don’t back any proof showing an improvement.
This backs up what I said above. Where’s the actual proof? We’ve seen dyno results that are effectively useless.Where’s the actual acceleration proof? I think the lack of hard data opens up inflated numbers. Like should be, or like you posted “i would say it’s worth”
The point I’m getting at here is. Mechanical wise how big if any are the differences? One company trying to sell a 2.0t turbocharger, provided a Photoshoped compressor map. essentially mechanically you don’t know what you’re getting with a ko4 or a S3 turbo.
My K0R (K04 with machined K03 compressor housing) was a worthwhile upgrade as far as driveability is concerned. Raw numbers aside, I think most people would be happy with the upgrade for daily use.
You ran your time in great da. The parameters of your pump tune are likely conservative enough that with your IC, 94 octane pump fuel and the cool DA you weren’t seeing much timing being pulled.
Unless you meant running race fuel and getting a race fuel tune. Could see some gains there.
