Installed the new K&N air filters today, and there is definitely a noticeable difference. My paper filters may have been dirtier than I thought (but still not THAT dirty). Anyways, throttle response is massively better, higher RPM torque is noticeably better… all around, it just feels like the engine is finally able to breathe. Highly recommended!
Installation, for those who haven’t done it, is pretty easy. Both sides are basically just mirrors of each other, except for a couple of vacuum hoses you have to contend with on the passenger side. I was able to do the install without unplugging the MAF sensors nor the vacuum hoses - I just removed the front vent tubes, loosened the 3 screws holding each intake box together, and removes the intake tubes to the manifold (the passenger one can’t be completely removed because of the attached vacuum hoses, but I suppose you could disconnect those if you want), then lifted/tilted the airbox so I could get to the filter. The stock filters did not have hose clamps, but the K&N’s each came with one, so I went ahead and used them to secure the filters. Blow out all the leaves and dead bugs before reassembling. I found some fascinating giant, dried beetles in there from the car’s former life in Texas ;D
Anyways, for around $100, this is definitely an upgrade that shouldn’t be ignored. I’m curious to hear if others report similar findings.
