Ok got a hold of someone who has done this on AZ. Below is what he wrote.
It’s actually quite easy. The instructions are awful (bad translation to english). I can’t remember exactly. but basically the connections for the dials are all ready, and you should only need to add ground and power. Power is added up at the fuse box. I believe ground is back at the seats. Those wire leads that Kufatec provides are designed to be added to empty positions in your fuse box up at the drivers door. Some are constant power and some are ignition. I can check to see what fuse position I used, if thats helpful. For how to physically “unlock” the fuse box and add wires, I would try google searching a bit -that’s what i did. If you can’t figure it out, I can help find a tutorial, too.
I found it easiest to uninstall almost the entire interior of the car. Having both front seats and the console out helped significantly when figuring out how to best route the wiring.
Does that help? feel free to text me with other questions. Dont hang around AZ a lot any more, unfortunately!
Luckily for me i am changing out the entire interior (pretty much). As far as adding the ground and power im going to ask him if he means i need new wires for this or just find places.
BTW my box came with NO INSTRUCTIONS. lol. Ill keep this updated. Hopefully within the next two weeks i can get this all done. Ill def do a write up on this when i do it. Help out others. Its crazy that something like this hasn’t been written up yet. I know its more of a “luxury” type of thing but still, surprised.
