REVO?
So you lost the dyno sheets? Can they mail them to you or email? Same day same dyno means they should be worth something.
Can you expand on the manual shifting with revo dsg software? You mean to say in manual mode it will allow you to bounce off the rev limiter and not auto up shift? I assume it will still auto downshift when you slow down to a stop light…
Did you get the program switcher so you can switch to the race file? With meth injection and the revo race file, you should be logging your car to make sure everything is ok. We know these engines are pretty stout, but in that case you will be pushing it pretty hard. Pretty sure Jeff has done lots of testing/logging to determine how the meth injection should work with each file.
I’ve asked them to e-mail them to me. When in manual one must up shift manually. I only did a little experimenting on the way home. Yes, it will not auto upshift while in manual like it did stock. Goes to 7000 and sits there. Did not roll to a stop in manual to see if it would auto down shift to first as it previously did…good question! Will check today. Will do some logging this week end. I, as of yet, have not gotten the program switcher but plan on it. I DO have a 30 day warranty on the install and the money is refundable in that period. Wanted to make sure it works properly first, currently set at 93 octane. Thanks
