Ok, so as some of you know, once in a while, I’m experiencing some bogging when accelerating.
Initially, JHM and I thought it might be related to the fuel trim levels and therefore tried a few different ones.
JHM’s 3rd tune nailed it spot on and now the fuel trim adaptation numbers seem just fine (from about 7-8% when babying the car and 0-1% when punching it hard which seems to be inline with the tolerances, i.e. doesn’t set off any CEL when on the low side and doesn’t run rich (i.e. no negative numbers on the high side).
The tune is now considered good (and the bogging was drastically reduced).
Now, the bogging ONLY occurs when:
- The car has been running over 3k rpms for at least 10-15 minutes (i.e. hot).
- Between 2k and 3k rpms
In other words, I’ll drive the car for 15 minutes at around 3300-3500 rpms on the highway, and when I use the offramp (i.e. slow down) and then accelerate again somewhere between 2k and 3k rpms, the bogging kicks in. Above 3k rpms, it seems ok.
What’s been done so far from a mechanical/hardware stand-point (all to no effect).
- Throttle body swapped from another car.
- Intake manifold swapped from another car. (both my own TB and IM were swapped back)
- All four o2 sensors changed for brand new ones.
- Downpipe had a neckdown to 2.2" which was annoying. Replaced with a proper 2.5" all the way through.
- Smoke test (no leaks). All PCV system quintuple checked.
- Fuel filter replaced.
Again, keep in mind this bogging only happens in very specific circumstances. It’s not something that happens all over the place.
Now, on the more POSITIVE note, the car pulls like mad with the new (proper) downpipe and new o2 sensors.
Here’s a 3rd gear pull log (I hit 878 RPMs/sec compared to saki’s (albeit non-carbon cleaned) stock RS4 of 688 RPMs/sec (saki, correct me if I’m wong on that one. I used the last log you posted) with an average of 780 RPMs/sec and a median of 800 RPMs/sec (and that’s with a box on the roof lol).
https://docs.google.com/spreadsheet/ccc?key=0Aifrh7MAi3ISdG5MVmU5TjlseDZTYUswWmJlcUxkbXc
As for some logs of the bogging, here’s a few cuts and paste (you’ll notice the RPMs are below 3k and the load goes up and down which is me giving it gas, car bogs, then let off gas).
https://docs.google.com/spreadsheet/ccc?key=0Aifrh7MAi3ISdGVjLVcyZ2N1TmR2djFjM2VENHBkaHc
Both spreadsheets are editable in case anyone wants to add comments and such. I have the originals.
Thoughts? Ideas? Suggestions?
