I’m hoping not a bad shock
Top mount perhaps, I do feel it sounds like it’s hitting top mount.
It’s only when going real slow and not all the time either. If going over slow bumps, I hate issues like this,.end up costing a fortune diagnosing as can guarantee the issue is the last thing you try changing
Usually bad bushings in the lower control arms are quite noticeable at slow speeds right when you accelerate or tap the brake pedal.
I lowered mine on JHM springs and it knocks pretty badly over slow bumps. I’m taking everything apart when some other parts come in. I believe it’s the top hat. There has to be some play between the top nut and the top hat, or a bushing failed completely.
If it’s the bushes Ive been looking at the powerflex ones apparently more durable. Can anyone recommend.
@hahnmgh63 - is always spot on. I think he’s got you pointed in the right direction on the knocking. Bushings and control arms can look ok at first glance but once you get closer you can tell the bushing is gone and that is almost always the knocking or clunking at low speeds.
Especially if you don’t feel it in the body or steering wheel - When it comes to replacement of bushings especially when they are the control bushings. I’d tend to say just look for a good deal on replaements in OEM form… They really last a good chunk of time and you don’t want to really go too harsh.
Lastly you can load a video or picture by dragging it into your post or if the video is live hosted on a specific place. You can drop a link in the thread
Like this
Thanks Guys,
I’ve just had tyre changed.
Michelin going to investigate it for me to see why it seperated as it did.
I had a look at the arms and bushes too but could see anything wrong with the eyes. I’m no mechanic at all though.
I’ll keep ears open next few days and maybe get it in for a check at a garage
Defo something not right. Time I think to get some pricing to get some bushes then I think
Booked in on Monday to get checked out. Will keep you posted
Shock absorber has gone. What do you guys recommend. That’s not going to kill my wallet
Probably just factory replacement. Each Shock body is about $200. When my suspension gives out I’m going coilvers and full 034 bushings with all new arms. Probably only $2000 for all of it.
Garage just quoted me £2000 to replace front absorbers with OEM ones.
I’ve seen full aftermarket kits for less.
Problem is I don’t have £2000
I have about £1000 and hoping to get something fitted within this too
Do you have DRC?
Yes I’m pretty sure I do anyway. I can go into dynamic and it all stiffens up if that helps
Yes thats DRC they do blanking kits for DRC if you choose not to go with a set up that use this !
One company I’ve heard about that people seem to be very pleased with and don’t break the bank is BC Racing Coilovers.
I’ve not used them myself but over here in the U.K people seem very happy with this setup I know a few guys with this set up not on our cars but BMW’s and a few Jap cars and they are impressed with them.
Its worth looking into as there good quality and around your budget !
I had BC BR Coils on my last 335is and they were great. I’ll be getting them on my RS5 eventually. Can’t recommend them enough because they don’t break the bank yet give me all the adjustments I want.
Thanks Steve.
I actually went for a Koni setup in the end.
I really didn’t want coilovers and after lots of research and testing people I came across CRS Performance. It’s a guy called Steve they talk alot about him on the RS246 forum. I think he must partner with Koni in someway as the shocks are not available on Koni catalogue. I think CRS shim them or something and state not to adjust as set for B7/B8 specific. It also comes with the electronic delete kit to remove DRC as well as the bung covers. They go on original springs but I beleive they also offer H&R springs as a pack to go with them.
Not really much info about really but sure if you Google CRS Performance it will come up with the chats.
I paid £970 for the kit.
Was supposed to be fitted today but my god what a nightmare. The bolt going to the hub snapped and for a moment thought was going to need a new hub. Managed to get the bolt out in the end but got to wait now till next week for it finished as didn’t want to risk snapping bolt on otherwide (rear drivers side) so getting that last one fitted but will be taking it very carefully and I’ll be twitching that day.
After that though I’ll let ya know what I think.
The DRC is also now fully removed and really won’t be missed tbh
Glad you sorted mate, Koni are a good make and have a good reputation so im sure you won’t go to far wrong with the choice you made.
I go on RS246.com and find it a bit boring to be honest everyone seem to be very oem with there cars ! No one seems to want to tune there cars to much or put different none oem parts on. There is a lot of talk about Audi servicing and how much there cars are worth in stock form etc etc … boring lol !! … Anyway
Hope all goes well with the fitting sounds like you have been having fun ! Im sure it will be easy from here in good luck buddy !
Yes RS246 although comes up alot not a great deal of activity although I could say that for a few forums.
I use this one mainly as I’m all about tuning haha
Hopefully at some point I’ll get round to that stage 2 tune
