Sorry about the Michelin’s, I’ve always had good luck but they’re not a cheap tire, any warrantee left in them?
You sound like you’re heading in the right directin being a control arm. The uppers usually go before the lowers but as a whole they don’t seem to last too long. Hard to see visually if it is just starting. Sometimes you can put a spanner across the flat portion of some of the arms and torque them a little side to side while inspecting the bushings for cracks in the rubber which pretty much disappear when unloaded. How many miles on the vehicle? Rare for them to go past 50~60k miles.
So wheel will be off tomorrow for a new tyre so I’ll have a look around. See if I can spot anything.
Cars got loads of miles on it. 104.000 now.
I’ve done about 25,000 in that myself so wouldn’t surprise me and to be honest a bush is better than a shock I suppose.
At that miles I would imagine the arms were replaced before you got it.
Do you think it could be the bushes
I think it definitely could be. But could it be a bad shock? Motor mount?
I’m hoping not a bad shock
Top mount perhaps, I do feel it sounds like it’s hitting top mount.
It’s only when going real slow and not all the time either. If going over slow bumps, I hate issues like this,.end up costing a fortune diagnosing as can guarantee the issue is the last thing you try changing
Usually bad bushings in the lower control arms are quite noticeable at slow speeds right when you accelerate or tap the brake pedal.
I lowered mine on JHM springs and it knocks pretty badly over slow bumps. I’m taking everything apart when some other parts come in. I believe it’s the top hat. There has to be some play between the top nut and the top hat, or a bushing failed completely.
If it’s the bushes Ive been looking at the powerflex ones apparently more durable. Can anyone recommend.
@hahnmgh63 - is always spot on. I think he’s got you pointed in the right direction on the knocking. Bushings and control arms can look ok at first glance but once you get closer you can tell the bushing is gone and that is almost always the knocking or clunking at low speeds.
Especially if you don’t feel it in the body or steering wheel - When it comes to replacement of bushings especially when they are the control bushings. I’d tend to say just look for a good deal on replaements in OEM form… They really last a good chunk of time and you don’t want to really go too harsh.
Lastly you can load a video or picture by dragging it into your post or if the video is live hosted on a specific place. You can drop a link in the thread
Like this
Thanks Guys,
I’ve just had tyre changed.
Michelin going to investigate it for me to see why it seperated as it did.
I had a look at the arms and bushes too but could see anything wrong with the eyes. I’m no mechanic at all though.
I’ll keep ears open next few days and maybe get it in for a check at a garage
Defo something not right. Time I think to get some pricing to get some bushes then I think
Booked in on Monday to get checked out. Will keep you posted
Shock absorber has gone. What do you guys recommend. That’s not going to kill my wallet
Probably just factory replacement. Each Shock body is about $200. When my suspension gives out I’m going coilvers and full 034 bushings with all new arms. Probably only $2000 for all of it.
Garage just quoted me £2000 to replace front absorbers with OEM ones.
I’ve seen full aftermarket kits for less.
Problem is I don’t have £2000
I have about £1000 and hoping to get something fitted within this too
Do you have DRC?
Yes I’m pretty sure I do anyway. I can go into dynamic and it all stiffens up if that helps
