Bear, I would say the LW rotors, lighter wheels and tires, etc are helping more in his 60’s than the tune, especially if he isn’t using the vaunted LC… I also think he gets the whole tire pressure optimization and shallow staging better than most…
Jeff was kind enough to send me his logs and I don’t think he will mind me sharing… He is bypassing a lot of boost and his IAT’s are way high for having a AWE cold front setup… The IAT’s I showed on a similar day low 50’s temp wise were about 10C better on average… Not sure if the system wasn’t purged correctly as I know others have had an issue with this… Or does the APR secondary pump help that much? His bypass valve opens quite a bit more than mine and mostly in the upper RPM’s before shifts… I also noticed his car over revs and goes over 7200RPM about a dozen times in 5 passes… The bypass reminds me of APR v1 before they sent me the few beta files and then came out with v2… I told him to send the logs to Austin and ask his thoughts since I’m sure he is more qualified than me…
His timing is very close to mine and he does have some timing retard but nothing that jumps out too bad… He pulled his MAF reading in a different measurement than mine so I haven’t compared that yet… IMO with a few small tweaks he will have the fastest car, which is why I made the title that I did, it wasn’t all tongue and cheek… lol
