I am a little upset no one invited me to the party. Being as unbiased as this place is I figured you guys would want to talk to me first hand,
Ill be honest, this forum I already love much more than Audi-zine, this is my first Audi so I didn’t know this forum existed.
Lets clear some things up before we go any further, lot of misinformation flying around here. I will make a timeline of events.
First Quarter Mile Pass Ever(got one run in and started raining) Late October 2012
45 Degrees out, negative DA(perfect conditions)
Stock tune
AWE Exhaust
APR Intake
13.1 @ 105.9 I believe
2nd Pass(best run of 3)
85+ degrees out with a DA over 2600
Stock Tune
Roc Euro Intake
Euro-code Headers
AWE Exhaust
12.9 @ 105.6/9
Make your own conclusions from that.
OK Now that those are out of the way, you guys seem to be confused about what I am doing with my methanol.
- Use water/methanol(mix was to be determined) on my 93 tune with 93 gas in tank to provide cooling and octane benefits.
- Use Methanol on the GIAC 104 tune with 93 gas in tank to provide compensation for lower octane fuel, thus allowing me to run the 104 octane tune with pump gas.
THAT’S IT - MY ONLY GOALS
Fast forward to first set of runs with methanol
93 tune GIAC Stage II full bolts on - METHANOL OFF
12.4 @112 I believe(you guys have seen slip)
Methanol ON Still on 93 tune
12.3 at 113.6 or something it was less than a MPH increase.
Lets think, same tune, same parameters, back to back, why would the car be any faster? Methanol has less PE than gasoline, the car might not have had time or the brains to add timing in a back to back situation. So Arin’s comments about not much of an improvement are true, but out of context. Of course there wouldn’t be much of an improvement.
THEN
104 Tune with 93 in tank, car runs 12.1 at 116.5 I believe, I provided a full graph of that run, it shows the car short shifting first at only 5300RPMS!!! The slip ALSO shows that out of the runs performed that night, my 104 tune pass had the crappiest 60’, combined with a short shift into 2nd at 5300 which surely screwed my 2nd gear pull, I think is pretty good guys.
Improvement? Yes, for what I intended to do.
Future
I have been talking with Ron and he is one great guy! I cannot wait to meet him and see what are babies can do. Oct 12 is our date.
- We WILL be using same fuel ideally, to avoid any BS. Either URT or MS109.
- When I use race gas I will do passes with meth OFF, and slightly on(partial cooling effect) THAT’S IT, just to see what happens. I will be experimenting, as that’s what this whole project of mine is.
This will allow for some good runs between me and Ron.
Hopefully we can get some highway runs in to see what the upper limits of these cars are capable of.
I have to get going but more to follow.
Happy Hunting Boys!
