Some Guy's Mediocre S4 Build Thread
I know which one you’re talking about but those are just two separate o-rings that just happen to look like that because of the way they’re oriented. I already set aside the oil filter housing o-ring and housing gasket
Another quick update! Everyone loves more updates!
I assembled the JHM updated mechanical adjusters!
http://i.imgur.com/srTfsRJ.jpg
A shot of the wallowing on my old adjusters
http://i.imgur.com/aD9nYu1.jpg
http://i.imgur.com/DwOGNTf.jpg
How bad is that? Doesn’t look horrible
Should be considered middle-of-the-road wear. I’ve seen people with better and with worse. Either way, I think the wait for the JHM adjuster repair kit was worth it
are the jhm ones made of a stronger steel? Or will they also wear out in the same lifespan
JHM ones are CNC aluminum. Stronger than OEM fo sho
So probably a longer lifetime than OEM which I suppose was 105,000 miles
aluminum? Aren’t the OEM ones steel? They felt like steel anyway I didn’t get to feel the weight. Aluminum is a bit softer though, wonder how they got it to be tougher. They certainly look pretty nice.
Idk man, you’ll have to ask the oracle of Jake
They are not aluminum lol.
Lol my bad. Didn’t make sense haha
The oracle has spoken. They are definitely not aluminum they are much harder then stock that’s very nice to see. Great updates keep em coming great work. Did you find out where those seals went.
Nope! No idea where in the world they’re supposed to go haha
I’m pretty pissed off at the moment because I just drove all the way to the powdercoater to check the progress… Last week, I dropped the stuff off on Tuesday and they said that they’d try and get it done by that Friday. I went today and they said they might be able to get them done by this Thursday. Like wtf!!! That’s like double the original eta. Not cool at all
Did you install the SAI Block Off plates yet?
Yep! Threw them on yesterday with the old gaskets but I didn’t take any pictures yet
Right on!
Any way you could find out for me what those seals are for that I posted about earlier?
http://i.imgur.com/J9HhiFS.jpg
Big one is the front crank seal, the others are the heater bypass pipe on the back of the motor. (black steel pipe)
Unless that is the 079-103-051E Seal, which would be the accessory seal on the power steering shaft.
Called it Phil!
Thanks Jake!
Also, back to a question I posted like a couple pages ago that’s really worrying me now… My front crank seal that I bought from you guys (Victor-reinz not oem) went on like suuuuper easy… It went on like butter. So I’m really worried about it leaking because it’s supposed to be so difficult to get on. Maybe because it wasn’t OEM, it was out of tolerance?
