Ive been reading lots of the 3.0 posts here and on AZ and thank god for this website ;D
There are a few guys who make the idea of going turbo sound so easy. To me they make it sound much eaiser then I think it would be. Ill lay out what it takes to convert to turbo but my question was for the money. say 8k what would you rather do. A PROPER supercharger or a turbo
So If your going to take your 3.0 and go turbo. your going to need AND PLEASE ADD TO OR EDIT
turbos. Now lets not go with the notion that anyone is going to get used turbos. I think you can get a set of cheap china ko4’s for say 1300$
So turbos 1500$
you need inlets 500$
your going to then need up pipes 400$
charge pipes 200$
DV valve 100$
you going to need a different throttle body boot but lets say you can still use your intake manfiold 100$
your going to need the turbo feed oil feed and oil return coolant return 500$
you going to need a install kit 100$
then your going to need turbo manifolds call that 500$
your going to then need new Dp’s so call that 700$ if you make them modifyed
your PCV syustem is going to need to be changed so add another 100$ for that
Then you have to make some kind of y pipe or you can just get a used one from a crashed B5 call that 100$
Then a fueling kit. when you figgure your going to need injectors MAF Vac hoses and lines to go to the waste gates. When you see used B5 fueling kits most people aare askling for about 1500$ then when you put in the fact that this car can’t use that fueling kit and its going to be something that needs to be tuned properly. Lets fuggure 2000$. This encludes any random needed little bits and bolts.
Now I know Im probably forgettign a few things and we also have to reamember that your going to need to pull your motor for this and then tap into the oil and coolant lines. Then tap into the oil pan.
price without I/C’s is 6800$ not too bad when you look at it. Still there are those odds and ends and lots of fabracation and adjusting that needs to be done.
On the other side is say a used PES or lets even throw in the possibilty of the JHM blower kit for the B6 S4 being able to be adapted to the motor with some tweaks. The jhm S4 kit is 7800 complete with fueling kit and it comes with a few things the 3.0 wouldn’t need like a 1000$ oil cooler to remove one of the Aux S4 rads. So there is a chance that the JHM kit could be 6800 as well…
If were talking about getting the most out of the 3.0 the first thing that your going to start with is the exhaust. Dp’s being one of them. clearly if you go turbo your doing tht mod twice. If you stay blower your not wasting that money.
now I know this Thread isa bit eairly in the developemnt of the new up and comming 3.0 platform but I thought I would throw it out there and get some thoughts
