Thanks giving clean upn
I was just flickin through youtube and saw your car on the dyno. what were the numbers?
I have an 4F RS6 wheel, if you want to check it out in person. It is currently unmounted.
hey that day we 390 whp on the mustang dyno, but my car had some problems like 02 sensor,maf, hpfp! It might be doing a but more now!:slight_smile:
Sorry, but I hate that clip. I know your car can do well above what they showed in that shit clip.
denis, whats your complete mod list?
ok!let me see if i can remember everything!
PERFORMANCE:
JHM 5r clutch w LWFW
Apikol rear diff
JHM trio shift
JHM SC kit stage 1
JHM LW crank pulley
JHM tune
034 maf hose
All the motor mounts from jhm
EB werks full exhaust DP and cat back
KWV3 coilovers
PLX gauge
IM spacers
Cosmetic:
RS7 rear caliper plate
Ziza lights
LED day light run
35% window tint all around
Pioneer navi w all function
FBSW
BC FORGED wheels HB 29 19x10 all around w 275/30/19 hankook
front bumper carbon fiber splitter
R8 oil cap
Porsche coolant cap
It think thats it!:slight_smile:
yea i know! :(my car definitely running way better now after we fixed those things, the 02 sensor and maf were making the car all crazy w codes and stuff running completely weird,we fixed that first , and then couple of months later the high pressure pumps failed, thats when i felt the car way better after we replace that and Dan did some adjustments on the TUNE!:slight_smile: the car has a better juice down low and top end, before then the top end of my car sucked!
I maybe wanna dyno again someday, but im not
Expecting my car to do way more then 400 whp on the mustang dyno!
Cant wait for the built/ stage 2:) !
performance wise im basically building your car lol.
Isn’t it true too that with the bad 02s the jhm tune won’t let you go to the 8000 rpm red line. I read somewhere that your car only made it to 7400 or something n close to that on that dyno run due to the bad 02s.
I’m lovin the car and the mesh looks great. Those rims look awesome
FWIW, mine allows the 8k rpm redline with a consistent O2 sensor CEL/MIL/DTC.
thanks for the rims!:slight_smile: and yea my car only went around 7600 rpm on the dyno
nice i hope u get everything working fine on your car so u can hit those under 12 sec on the 1/4 mile,and put a smile on your face!when it will be ready?
yes I most definitely will get it working correctly. I think im just gonna go ahead and replace the front o2s now my rear ones were just replaced and the fronts are likely gonna go soon.
It was only 30 whp less than an AMD high boost kit, and you were 70 whp more than a car with same full ebworks exhaust and an Apr tune, so it wasn’t that bad really. That dyno has been pretty much a heartbreaker since they installed it a couple years ago.
Going to 7600 on a supercharged rs4 means you’re missing the peak. Probably 20-30 whp right there.
After i brake in my new 5r clutch i maybe wanna try again dynoing my car and maybe even take it to the track!
Do it man. We need stage 1 times for the board. My first stop once my clutch is broken in is the track. And I’ll likely hit the dyno too.
There’s a awd dyno here in oakville that a few rs4 dyno results have been posted from already, as well as a JHM supercharged B7 S4 (axel) .
Shop is called neetronics I believe.
ya that’s exactly where I was gonna go. mistro mentioned them to me when I first started posting. I should have done a session while I was still n/a.
I have to take mine to the same spot at 034, cuz i have done the last one there so they have all the records! Hopefully i got some extra HP from last dyno!:slight_smile:
