what’s an RS4r
The K04s I’ve been running for 5 years. It’s a PJ K04 housing with GT28 turbines… It’s why my car is racekor.
Lol jk. I was just messing around with Pinoy when he said he was doing something different than RS6r’s.
In my mind I’m sure Pinoy is doing K05 prototypes. Watch out for prototypes unless they come directly from JHM.
lol what’s K05?
K05-Rs. Sorry.
what’s that???!!! I have no idea seriously. Is that a new turbo being put forth for the B5 guys?
CV mentions these in his most recent post in ZT’s build thread. No specs but evidently it’s another prototype or something.
Lol mysterious B5 turbo will remain mysterious.
It’s an attempt to get the B5 guys what they have been asking for since the RS6 turbo(s) originally came out. From what I know its never been done before and its always been an idea I had kicking in my head. After seeing lots of comments on the available selection of turbos and what people wanted to see, it’s an attempt to see if we can make the golden goose of turbos for the B5.
Did that make it even more mysterious? All I will say is, this isn’t about getting people more dyno sheets. I think the platform has seen enough of that in the past. This is a genuine attempt at getting the right size turbo for the masses. The RS6-R turbo and the RS6-R (T) will make well over 530whp (with the right supporting mods) and we have even seen the OEM modded RS6 turbo make over 550whp with the spool very k04ish. Even with that, people are asking for a different turbo. When you actually make the turbos its amazing how you can just change what you want when you want to. The ko5 is nothing more then an experiment. It won’t be sold till it works and it might take 2 more years of testing to get it down to what JHM is looking for.
The K05 is in the testing phase and its being sorted out just like the RS6 R and RS6 R (T) where they are only given to people who are able to do their own mechanical work and can give feedback.
I thought b5 guys only wanted dyno sheets?
Because when you post about it ask for quarter mile times, u get stacked (by empty headed customers and vendors alike)
I’d “like” a dyno sheet but I demand real world results. When my car is finished I want to know what it can do. I’d also like to provide future B5 S4 owners with the ingredients to specific expectations.
Ha ha ha…
ME! ME! Received a set from JHM in February my 2000 Audi A6 2.7T 6 speed
Drivetrain
APB Block, 82mm bore
ATQ Heads fully built, new guides and lifters, polished cams, mildly ported and all Supertech Valvetrain (Inconel, Nitrided SS, Spring Kit)
3L Crank, polished, re-balanced for
Wiseco 8.5:1cr Forged Pistons
Pauter X-beam Rods
ARP Main Studs
034 Coated Bearings throughout
Eurospec Non-Stretch Head Bolts
Heavily Ported Stock Exhaust Manifolds (enormous PITA. No wonder VAST used to charge so much to do it)
Heavily Ported Stock Intake Manifold
Clutchmasters Stage 4, 6 puck single disk. Machined OEM Flywheel
Deatschwerks 320lph in tank pump mounted inside stock gutted pump
JHM RS6R Turbos
ARDesign '05.5 AR Aluminum TBB, 2.125" Bi-Pipes
ARDesign 3" Downpipes
DIY 3" to 2.5" mid-pipes
DIY Dual 2.5" Exhaust (2x Magnaflow 10426, 2x Magnaflow 11226)
ARDesign 95mm MAF tube/K&N open air element
Bosch Racing Porsche 997 650cc @ 3 bar Injectors
SRM SMICs
Innovate LC-1
DIY PCV System, Air/Oil Separator
DIY Oil Cooler
EFK, switchable between Manual and Auto
etc etc
Now with DIY Upgraded Cross Rod thanks the diy in this forum
Chassis
Koni Sport Shocks w H&R Sport Springs. Fronts are Sleeved, Rears have 4 grooved height settings
B5 S4 rear calipers with B7 S4 rotors. 034 caliper spacer
Porsche Cayenne 17Z Front Calipers over D/S 330mm Volvo V70R Rotors. 18Z Centric ceramic pads
Hotchkis F/R Sway bar Kit
034 Street Density Control Arm Kit w Adjustable Uppers
034 Street Density Engine and Transmission Mounts
JHM DTS
034 Snub Cage/Mount
I;m currently servicing the car after break-in. Re-torquing head bolts, checking plugs, compression test, check/repair and leaks, loose bolts, add zipties to all the wiring, figuring out where to permanently mount the boost gauge and wideband display, remounting intercoolers for the ARDesign bi-pipes.
Car feels amazing. Much more low-end torque, and very quick spool. Positive Pressure at 2500 rpm, and fully spooled by 4000 - which is not a lot of elapsed time.
Next track day at Firebird is May 12th. I’m hoping to have it ready to go then.
http://imageshack.us/a/img163/527/imag0695p.jpg
http://imageshack.us/a/img823/6471/imag0607k.jpg
http://imageshack.us/a/img18/6880/imag0702k.jpg
http://imageshack.us/a/img802/7471/imag0847f.jpg
http://imageshack.us/a/img9/7665/clutch003i.jpg
http://imageshack.us/a/img694/4056/motor3h.jpg
http://imageshack.us/a/img15/4922/imag0845y.jpg
http://imageshack.us/a/img51/218/0316031106.jpg
Nice!
That’s a pretty incredible list.
Who tuned it? What fuel are you running? What is firebird?
Drivetrain
APB Block, 82mm bore ATQ Heads fully built, new guides and lifters, polished cams, mildly ported and all Supertech Valvetrain (Inconel, Nitrided SS, Spring Kit) 3L Crank, polished, re-balanced for Wiseco 8.5:1cr Forged Pistons Pauter X-beam Rods ARP Main Studs 034 Coated Bearings throughout Eurospec Non-Stretch Head Bolts Heavily Ported Stock Exhaust Manifolds (enormous PITA. No wonder VAST used to charge so much to do it) Heavily Ported Stock Intake Manifold Clutchmasters Stage 4, 6 puck single disk. Machined OEM Flywheel Deatschwerks 320lph in tank pump mounted inside stock gutted pump JHM RS6R Turbos ARDesign '05.5 AR Aluminum TBB, 2.125" Bi-Pipes ARDesign 3" Downpipes DIY 3" to 2.5" mid-pipes DIY Dual 2.5" Exhaust (2x Magnaflow 10426, 2x Magnaflow 11226) ARDesign 95mm MAF tube/K&N open air element Bosch Racing Porsche 997 650cc @ 3 bar Injectors SRM SMICs Innovate LC-1 DIY PCV System, Air/Oil Separator DIY Oil Cooler EFK, switchable between Manual and Auto etc etc Now with DIY Upgraded Cross Rod thanks the diy in this forumChassis
Koni Sport Shocks w H&R Sport Springs. Fronts are Sleeved, Rears have 4 grooved height settings B5 S4 rear calipers with B7 S4 rotors. 034 caliper spacer Porsche Cayenne 17Z Front Calipers over D/S 330mm Volvo V70R Rotors. 18Z Centric ceramic pads Hotchkis F/R Sway bar Kit 034 Street Density Control Arm Kit w Adjustable Uppers 034 Street Density Engine and Transmission Mounts JHM DTS 034 Snub Cage/MountI;m currently servicing the car after break-in. Re-torquing head bolts, checking plugs, compression test, check/repair and leaks, loose bolts, add zipties to all the wiring, figuring out where to permanently mount the boost gauge and wideband display, remounting intercoolers for the ARDesign bi-pipes.
This sounds like a similar build to mine. How long did it take to get it together? Mine is going on 13 months and it looks like it’ll be a couple more - though I did have a couple of issues along the way.
I am tuning it, and here is where I am at:
- AFRs are safe, but need fine tuning.{/li}
- Timing is safe, but still very flat.
- With a goal of being a comfortable daily driver, this first tune is being built using pump 91. I will also setup a couple fuel specific tunes shortly.
I am still researching what other fuels I would like to use, and I certainly wouldn’t mind input! Plan is to start with street legal Sunoco 100. From there, it’s new territory. This place is only two miles from my house: http://www.unitedoil.net/race_fuels.htm. Not a great selection of unleaded, but I’m not complaining.
Firebird = Firebird International Raceway
[quote=“Zero_Tolerance,post:116,topic:3981”]
I started in September. A good portion of the time has been spent waiting for “the next paycheck”, so as to not get in debt. I had everything for the motor build portion in September, but had to wait until after Christmas for the turbos / clutch / bolt on parts.
It’s actually been a nice way of doing it for several reasons: 1) I couldn’t rush things - I ended doing spending a lot more time ensuring things were done correctly, 2) Spent more time researching things, and 3) I got bored and painted damn near everything as I went so it should be pretty easy to wipedown/clean up parts and find leaks.
I started following your build long before I joined AR. These turbos have an amazing powerband. I hope you are fully up soon!
[quote=“Disrepos,post:118,topic:3981”]
Good to have another member welcom
Great attentedntion to detial…dont sell yourself short start a build thread so we can all see more on your car…
any updates on this build?
