I’d pay something that starts with a 3
The RS4 basically came with 1 option…the premium package. It was like $4000 and included nav, memory seats, auto dim mirrors just about everything. etc. So it’s hard to find one without it really, so keep that in mind.
What to look for is tough. Just drive it and get a feel for it. See if it clunks going over bumps (could indicate a failure in the DRC suspension, which is a few grand to fix). There was a recall on it, but just about every car on earth has had it done. Everyone will tell you ‘CHECK THAT THE RECALL FOR DRC WAS DONE!’ but that’s like saying check that it has four wheels. They’ve all been done.
Otherwise check the bottom of the doors for rust…some of the cars have developed some rot there.
Drive it and when it’s warm, run it to redline in 2nd and 3rd. See if it feels fast (sounds funny, but just give it a rip). See if it runs nicely to redline. See if in 2nd and 3rd you feel the car get a second wind at 5500 RPM, and sort of start taking off.
Is it from an Audi dealer, with CPO? If so, I wouldn’t worry about much, but if not, I would certainly ensure that the engine is in good shape. Find out if it’s burning any oil (although I don’t know how…but ask them straight up). If it has a problem, and needs a new engine, that’s about $20,000. You can just sleeve the cylinders to fix a fucked up block on these cars. It’s a replacement or nothing at this point.
The cars are really fun and have a ton to offer. What are you driving now?
What colour is the car? Any modifications to it? (hopefully its stock).
Take it in 6th gear at 25 mph and go full throttle…see if the clutch slips at all (little RPM spikes as it spins loose)
Also, post some pics, and we’ll tell you if the gaps look normal. Preferably a head on front end shot.
Here are some costs for stuff that may need replacing…so you can factor these in to your purchase price if they do
tires - 1200-1400 or so for a set of 4 good ones
brakes - front rotors are $300 each, pads are another $300 or so, labour is $180 and fluid is $150. So about $1500 all in for a full front brake replacement. Rears are about 40% cheaper.
