it has a 1/4" pipe connection, so you put whatever fitting your compressor uses. The difference between the 2 airllift units is one is plastic, one is metal.
The schwaben unit looks really nice, and for the price its better than the airlift.
I bought it when i had my b5, and it bleed the heater core no problem, which is usually the pain.
What i would actually do, and was similar to what i did with my b8 when i had the charger off, do drain all the coolant like what the AMS instructions say to do, just get a coolant pliers, and squeeze the hose going down from the reservoir. This will leave the coolant in the radiator loop. Just undo the hoses for the excahnger and let that out. If using the air bleeder, it will just suck out the air from the system, it will just fill only that part back up(you remove the coolant pliers).
