Actually the 770 car was not running more boost… go read the OP 30 psi w/ the EBAY FMIC. And if you read the JHM thread they say they’re “around 30 psi” I’m going to say they were running more then 30 and not less.
Either way most of your post has been completely false.
Well some of what he said was true.
E85 requires a much larger amount of fuel to acquire a power burn mixture. So there is a large benefit to E85 on spooling turbos in just the shear volume alone it takes to acquire a power burn… So you can expect a 500rpm (or more) earlier spool time. Not only that but due to this you can spool the turbos much faster due to the larger expel of exhaust. A good example. You can spool your turbos up faster by running rich on standard fuel for a few hundred RPM. Lets say on start of spool up you run a 9:1 A/F (JUST AN EXAGGERATED EXAMPLE) that will help spool up the turbos. The sure volume of fuel your using will be used to help drive the comp wheel. Much like what people do on a bang box. Where they shoot unburnt fuel threw the turbo to help spool the turbo at standstill. Take all that and realize that E85 has close to a 9:1 raito just for Iddle… That should say something right there. Or at least I hope it helped make my point
E85 also has cooling property yet it doesn’t work exactly how your saying. You have the idea and concept but Its a little complicated to explain in just a few paragraphs. Still While I would say what your saying is true that isn’t going to negatively effect as you have suggested.
E85 is worlds different then race fuels. As a compound fuel its Well beyond what your going to see with even the best race fuel. Being a turbo car E85 is the best way to go. It will help cylinder temps spool and over all power. While this isn’t meant to say you can’t use results from one to the other. It would definitely not be a apples to apples. 1 good example is the E85 RS6 car that judeisnotobscure has spoken about. Your not going to get those same 500+whp figures out of a standard race gas Rs6 car.
For the sake of conversation we all might want to take that into consideration.
For 100% clarification the JHM car was running the same volume IC but it was not running 30lbs of boost. It was 26lbs of boost. However you can argue that due to the JHM car having RS4 parts the pressure drop would equal that of say 28lbs.
