Pulled Codes, found the following:
4 Faults Found:
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 202389 km
Time Indication: 0
Date: 2018.10.30
Time: 17:48:08
Freeze Frame:
RPM: 2587 /min
Load: 21.6 %
Speed: 119.0 km/h
Temperature: 76.0°C
Temperature: 10.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 203305 km
Time Indication: 0
Date: 2018.12.30
Time: 13:59:57
Freeze Frame:
RPM: 678 /min
Load: 25.9 %
Speed: 6.0 km/h
Temperature: 72.0°C
Temperature: 18.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.843 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 203305 km
Time Indication: 0
Date: 2018.12.30
Time: 14:07:52
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 26.0°C
Voltage: 8.001 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 203308 km
Time Indication: 0
Date: 2018.12.31
Time: 10:26:09
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 14.0°C
Absolute Pres.: 960.0 mbar
Voltage: 11.430 V
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L JHM/V3 9XSI ª0010
Revision: 5HH02— Serial number:
Coding: 01050009190F0160
Shop #: WSC 24103 444 13994
VCID: 234FF0E4E2B9BF52E6-8076
7 Faults Found:
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 200420 km
Time Indication: 0
Date: 2018.09.30
Time: 17:17:43
Freeze Frame:
RPM: 671 /min
Load: 36.1 %
Speed: 2.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 12.827 V
000775 - Cylinder 7
P0307 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 200420 km
Time Indication: 0
Date: 2018.09.30
Time: 17:17:43
Freeze Frame:
RPM: 671 /min
Load: 36.1 %
Speed: 2.0 km/h
Temperature: 46.0°C
Temperature: 44.0°C
Voltage: 12.827 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 200420 km
Time Indication: 0
Date: 2018.09.30
Time: 17:18:47
Freeze Frame:
RPM: 681 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 56.0°C
Temperature: 42.0°C
Voltage: 13.335 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 203305 km
Time Indication: 0
Date: 2018.12.30
Time: 14:00:11
Freeze Frame:
RPM: 853 /min
Load: 24.7 %
Speed: 5.0 km/h
Temperature: 73.0°C
Temperature: 18.0°C
Voltage: 13.589 V
004874 - Cylinder Disabling
P130A - 001 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 203305 km
Time Indication: 0
Date: 2018.12.30
Time: 14:00:50
Freeze Frame:
RPM: 3275 /min
Load: 56.8 %
Speed: 44.0 km/h
Temperature: 73.0°C
Temperature: 15.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 203305 km
Time Indication: 0
Date: 2018.12.30
Time: 14:07:52
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 26.0°C
Voltage: 8.001 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 203305 km
Time Indication: 0
Date: 2018.12.30
Time: 14:08:27
Freeze Frame:
RPM: 1073 /min
Load: 24.3 %
Speed: 13.0 km/h
Temperature: 71.0°C
Temperature: 20.0°C
Voltage: 13.843 V
Replaced all the coils and plugs and carbon clean clean within the last 5K miles.
High pressure pump?
Read something about a purge valve?
Thanks for any suggestions!
