I guess the constant engagement of the clutch at low rpm with more torque would do more damage in the long run than more of a peak spike of torque later in the rpm range. Because after all no one’s always in that range, whereas more torque at lower rpm is something you’d deal with every shift and on more of a day by day basis.
The 5hp I have seems to have held up fine between 450-500ft lbs of torque.
Yeah I’m starting to see more and more I research the 6hp19s holding up… They’d probably be pretty sturdy with the tune and built.
My main goal with the post was to see if there were any horror stories of toasting them at a certain torque level.
