Transmission overheating
Hey guys I’m getting a code for the transmission overheating p0634
Thursday,22,July,2021,20:32:50:37531
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
VIN: WAUGN74F57N029270 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 36 37 42 46 47
4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN74F57N029270 Mileage: 116620km-72464miles
07-Control Head – Status: OK 0000
08-Auto HVAC – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: OK 0000
36-Seat Mem. Drvr – Status: Malfunction 0010
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: OK 0000
61-Battery Regul. – Status: OK 0000
65-Tire Pressure – Status: Malfunction 0010
76-Park Assist – Status: OK 0000
77-Telephone – Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09— Serial number:
Coding: 01050009190F0160
Shop #: WSC 08101 444 53918
VCID: 221DE3E888C6D8ABB97-8076
4 Faults Found:
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116619 km
Time Indication: 0
Date: 2021.07.16
Time: 05:41:57
         Freeze Frame:
                RPM: 2082 /min
                Load: 34.9 %
                Speed: 45.0 km/h
                Temperature: 108.0°C
                Temperature: 45.0°C
                Absolute Pres.: 1010.0 mbar
                Voltage: 13.462 V
049409 - No Communication with Transmission Control Module
U0101 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116619 km
Time Indication: 0
Date: 2021.07.16
Time: 05:41:57
         Freeze Frame:
                RPM: 2525 /min
                Load: 22.7 %
                Speed: 45.0 km/h
                Temperature: 45.0°C
                Voltage: 13.081 V
008196 - Intake Manifold Flap; Bank 1
P2004 - 002 - Stuck Open
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116619 km
Time Indication: 0
Date: 2021.07.16
Time: 05:46:40
         Freeze Frame:
                RPM: 1906 /min
                Load: 15.7 %
                Speed: 53.0 km/h
                Temperature: 54.0°C
                Voltage: 12.319 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116620 km
Time Indication: 0
Date: 2021.07.16
Time: 05:49:49
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 112.0°C
                Temperature: 54.0°C
                Voltage: 11.557 V
Readiness: 0010 1101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0010
Revision: --H01— Serial number: 0087899
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2F3B1ADCCB1465C3269-807A
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
VCID: 313F1CA4DD20733330D-8064
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000481449
Coding: 0000007
Shop #: WSC 06402 785 00200
VCID: 6393A6ECD75C91A3F21-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 393FP067500038
Coding: 0010003
Shop #: WSC 00000 000 08192
VCID: 323D13A8D826482B497-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000467789
Subsystem 3 - Serial number: 0110.07.060000000100011443ÿ
Subsystem 4 - Serial number: 011443ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030142529
Coding: 0524330
VCID: 5BE39E0CEF2CA963BA1-800E
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 15
Mileage: 116620 km
Time Indication: 0
Date: 2021.07.16
Time: 05:52:36
         Freeze Frame:
                Temperature: 47.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115121
Shop #: WSC 02335 785 00200
VCID: 303919A0D62A7A3B3F3-8064
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 270BF2FCEFE43D83EE9-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F2029645
Shop #: WSC 00000 000 00000
VCID: 2809F1C0EEFA32FBE73-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 15
Mileage: 116620 km
Time Indication: 0
Date: 2021.07.16
Time: 05:52:33
Shop #: WSC 22161 444 83802
4 Faults Found:
012823 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
P3217 - 004 - Open - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116591 km
Time Indication: 0
Date: 2021.07.16
Time: 03:56:40
         Freeze Frame:
                RPM: 654 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 74.0°C
                Voltage: 13.335 V
012871 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
P3247 - 004 - Open - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116591 km
Time Indication: 0
Date: 2021.07.16
Time: 03:56:40
         Freeze Frame:
                RPM: 654 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 74.0°C
                Voltage: 13.335 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116619 km
Time Indication: 0
Date: 2021.07.16
Time: 05:41:57
         Freeze Frame:
                RPM: 2509 /min
                Load: 23.5 %
                Speed: 45.0 km/h
                Temperature: 45.0°C
                Voltage: 13.208 V
008197 - Intake Manifold Flap; Bank 2
P2005 - 002 - Stuck Open
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 116619 km
Time Indication: 0
Date: 2021.07.16
Time: 05:46:41
         Freeze Frame:
                RPM: 1904 /min
                Load: 14.5 %
                Speed: 53.0 km/h
                Temperature: 54.0°C
                Voltage: 12.319 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7G AIRBAG AUDI8RH29 0400
Revision: 01H29000 Serial number: 003BMD000K0Q
Coding: 0014151
Shop #: WSC 08159 444 85931
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME107F3E2FI
Subsystem 3 - Serial number: 6342CSME107E082B5
Subsystem 4 - Serial number: 6352QSME0F2E263BU
Subsystem 5 - Serial number: 6362QSME1037084FG
Subsystem 6 - Serial number: 63734SME0E69353DB
Subsystem 7 - Serial number: 63834SME11581043P
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026061890037
Coding: 0012141
Shop #: WSC 02323 785 00200
VCID: 6695BFF8246EE48B15F-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 Q
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5H337R576
Coding: 2129263
Shop #: WSC 08101 067 57207
VCID: 2313E6EC97DCD1A3B21-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B067038018
Coding: F5D5DEF7307A06
Shop #: WSC 02334 785 00200
VCID: 6C81CDD03A82DEDB43B-8038
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FACE4CD4083B3E0D-8034
1 Fault Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 116620 km
Time Indication: 0
Date: 2021.07.16
Time: 05:52:31
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381FK067502811
Shop #: WSC 08101 444 83282
VCID: 2E0507D8CC1E6CCB2DF-807A
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: 2C010DD0FA021EDB03B-8078
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01015926010000
Coding: 4618269
Component: LIN BACKUP HORN H02 1301
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 15
Mileage: 85830 km
Time Indication: 0
Date: 2016.01.19
Time: 07:52:46
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 28
Reset counter: 96
Mileage: 112353 km
Time Indication: 0
Date: 2006.03.16
Time: 14:25:06
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000008417
Coding: 0000026
VCID: 2517F8F499E82F93DC5-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000030638
Coding: 0012014
VCID: 5EE59718FC3EBC4BDDF-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04—
Coding: 0008022
Shop #: WSC 02324 785 00200
VCID: 1F1BEA1CBBB4F543969-804A
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FF4C4F5F00BF3F8D-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 15
Mileage: 116616 km
Time Indication: 0
Date: 2021.07.16
Time: 05:52:32
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394G+067661758
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000069451
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2607012931
Coding: 344630393135313035442056413032363037303132393331
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900025689
Coding: 0062725
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 49
Mileage: 116269 km
Time Indication: 0
Date: 2021.07.10
Time: 15:43:10
         Freeze Frame:
                (no units): 0.0
                Voltage: 6.70 V
                (no units): 42.0
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 253
Reset counter: 55
Mileage: 114940 km
Time Indication: 0
Date: 2021.06.27
Time: 09:52:45
         Freeze Frame:
                (no units): 52.0
                Temperature: 26.0°C
                Error Code: 1
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606230018
Shop #: WSC 12336 024 394758
VCID: 343115B02232461B5BB-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J6620TQ
Coding: 1000204
VCID: 5DE79014F138A753C45-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220619205014
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BF2FCE3E43D83EE9-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005086687
Coding: 0000000
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 15
Mileage: 116595 km
Time Indication: 0
Date: 2021.07.16
Time: 04:10:48
End----------(Elapsed Time: 02:03, VBatt start/end: 12.2V/12.1V)-----------
The Ross tech said the temperature was at 276 degrees
I recently purchased a new thermostat coolant hose that goes to the trans. Also connected to the after run water pump but not sure
I think it’s the thermostat for transmission because I pressed on side where the coolant comes out before it hits it and it had fluid and when I check the other side I didn’t feel any fluid
Could I just run the hose straight without the thermostat or do I have to use one and replace it?
It may be worth a shot but that hose goes between the subframe and trans. Not sure how easy it would be in car but I bet it’s possible. Audis are always made with tricks in mind I’ve noticed over the years
I know for a fact you can activate the secondary water pump via vcds but again not sure if that went to the trans I took all the hoses off earlier and dont rem now
The thermostat is about 3" long so you would want a coupler or new hose maybe. The new hose cost me like 160 or 200, nasty
The hose is very easy for me to access without a problem. It’s literally right there I’ll open it up and take a look
Okay so I did it and it took a long time for it to heat up I around for an hour. The temperature gradually went up. It stayed steady at 100c when I was parked and when I started moving again it went to 112 slowly and I cut it off. By the way the temperature jumps for example it would go 105 then 106 then 105 a couple times before it would stay at 106 and it’ll start doing it to 107 after. I assume this isn’t good temperature for it. I feel the transmission isn’t getting enough coolant to it. Maybe the auxiliary radiator is clogged? I’m not sure
Yea that pump goes to the ATF oil to water cooler. Did you try testing it? Could be broke, no flow.
It’s possible I remember I was getting codes for it shorting out and I heard a buzzing noise from it. I don’t see any codes for it and how do I test it on the Ross tech I only see it to test the relay
Believe you run output tests in the engine module
Yeah I looked in there. The relay was there for it but no option for the pump. It wasn’t there at all
Did you check the 2nd engine computer? Lol yea I dont know, maybe I was imagining
Yes lol but I’ll look again
If you are just trying to see if the pump works, energize the relay. If the pump does not come on, check the voltage at the pump terminals directly to confirm that the relay is indeed working. If you have voltage and the pump is not coming on, replace the pump.
Ok thank you and what is the transmission temperature supposed to be anyway
The regulator/thermostat in the coolant return line from the atf and gear oil coolers starts to open at a coolant temp of 80C.
The after run coolant pump will come on if the atf hits 120C. It will also come on at other times if the engine ecu deems it necessary.
ATF temp will vary depending on load and ambient temp. Between 80 and 105C seems pretty typical
Eng I appreciate your articulate info again, value add to the forum!
I’m replacing my pump “just cuz I’m there” $300 or so
Thank you
