You can give it a shot. It’s actually been done several times. Both acceleration wise and I think 1 of the guys that did the lambo did a dyno test and found that he lost 45whp down low and didn’t pick up but maybe 5hp up top.
The best option before you do anything like this would be to just open the intake and gut the intake. There have been several acceleration and dyno tests for this. Both of the test that are on here can be found I’ll search. but it falls into the same as the short runner intake. You loose about 30whp down low and then up top is about the same perhaps slightly more.
Tuning has nothing to do with it. You can have the best custom tune there is and bad hardware is bad hardware. The fact is your cams have a duration and overlap for the multi stage intake. The cams and motor RPM are not set for high rpm short runner gains. As it’s been stated. Look at turbo cars they all have short runner intakes. Look at NA cars that run below say 7000 and look at all their intakes they all share the same things for a reason.
So in the end it’s a hardware issue not a software issue. Again if it was me and I’ll try to search to help find the results already posted on here and create a new post to help @jollo1994 sorry to spam your thread with intake stuff.
I couldn’t have less interest in your project but don’t want to derail your thread. as this seems to this point be the most talked about part of your project. LOL And I’m thinking this isn’t the thing you’re looking for people to talk about.
