Richi was saying his car was getting choppy at 120mph at around 6k in 4th. Mine doesn’t get choppy but honestly just feels like it stops pulling, almost like detonation. I’ve logged third gear multiple times and the only issue that we see is some slight timing pull on pump, none on race and the supercharger bypass valve opening up to 25%. Here’s the thing even though there is 0 timing pull on race gas I still get this at around 120. This however doesn’t happen in the top of third. I want to get some fourth gear logs and see what’s going up but even in some fourth gear logs Richi’s logs last night looked fine if I recall correctly.
Here’s the thing like Tsivas said: his car is a 6MT and doesn’t have the issue, my car didn’t have the issue prior to the CPS/Testpipes/Clutch install. It’s def not clutch related, and that only leaves two other variables. Being cat-less and have CPS- two things mine and Richi’s car have in common.
We saw that my car with the Testpipes and CPS made almost no difference in my 60-130 time however my 50-130 was .3 seconds faster which obviously a gain from the Testpipes since CPS only helps in consistency rather than a performance gain.
In Richi’s car we saw this gain up top from his cat-less system. I just don’t know whether to point my finger at my Testpipes or a CPS issue. However something is NOT right.
The bypass valve is def an issue in itself and I should be making 1.5-2psi more from 4500 to redline however I don’t think I can solely point my finger at GIAC.
I’m not 100% sold on the idea that the Testpipes didn’t help me up top- that just doesn’t make sense to me. I’m waiting for a new file from GIAC to “fix” the bypass issue and also will be getting the pulley available from AWE hopefully this coming week. I will test this with Tsivas. Logs, vbox, 1/4 mile, pump and race etc…
We will see what GIAC has come up with and see what I can do about the CPS issue I’m assuming I have. Time will tell. If GIAC’s results aren’t good and I’m not satisfied and I decide I’m keeping this car for the long term Arin will be getting a call from me…
