just found some time to finally install vcds and see what codes my car is throwing looks to me like o2 sensors and intake manifold flap. it says something about a fault in the se3cond computer, how do I scan the second one?
I"ll post the entire log below, I just did the autoscan and this what I got.
Thursday,11,September,2014,21:27:16:00498
VCDS – Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WUARU78E57N900137 License Plate: BRCY297
Mileage: 151060km-93864mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUARU78E57N900137 Mileage: 151060km/93864miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.4L 91/V6 JHM ª0060
Revision: --H09— Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 93008 999 83881
VCID: 2447CDB6E7DA0D3EDFF-8071
5 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 56
Reset counter: 255
Mileage: 149198 km
Time Indication: 0
Freeze Frame:
RPM: 762 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 39.0°C
Temperature: 26.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.589 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 179
Reset counter: 255
Mileage: 150389 km
Time Indication: 0
Freeze Frame:
RPM: 775 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 45.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.716 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 150793 km
Time Indication: 0
Freeze Frame:
RPM: 1869 /min
Load: 17.2 %
Speed: 49.0 km/h
Temperature: 93.0°C
Temperature: 34.0°C
Voltage: 13.335 V
000313 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 150827 km
Time Indication: 0
Freeze Frame:
RPM: 1920 /min
Load: 17.2 %
Speed: 50.0 km/h
Temperature: 93.0°C
Temperature: 34.0°C
Voltage: 13.208 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 151064 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 63.0°C
Voltage: 11.811 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B55268A8A04C2461E5-807E
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6DD1E89227900C76401-5106
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0704
Coding: 01023
Shop #: WSC 65536
VCID: 3B7516CA296452C68E5-4B1A
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
004416 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 008 - Internal Resistance too High - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 24
Reset counter: 255
Mileage: 149297 km
Time Indication: 0
Freeze Frame:
RPM: 6660 /min
Load: 79.2 %
Speed: 175.0 km/h
Temperature: 92.0°C
Temperature: 31.0°C
Absolute Pres.: 950.0 mbar
Voltage: 12.319 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001NW35
Coding: 0433607
VCID: 3C7715D67F6A55FE87F-8069
Subsystem 1 - Serial number: 6332DRB402E04C26N
Subsystem 2 - Serial number: 6342DRB402E490B1P
Subsystem 3 - Serial number: 6352ARB401097FDC$
Subsystem 4 - Serial number: 6362ARB401088E58R
Subsystem 5 - Serial number: 63729RB4010A70258
Subsystem 6 - Serial number: 63829RB4010A70406
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 04441
Shop #: WSC 06335
VCID: 44876D36549A2D3EFFF-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0030
Revision: 0030 Serial number: 00000000000000
Coding: 0023301
Shop #: WSC 93204 999 85775
VCID: 2C5725968C0AC57E17F-5140
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023301
VCID: 2C5725968C0AC57E17F-5124
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: F1E974E2BBA86896E49-4B00
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H72 0200
Revision: 03S Serial number: AUZBZ7F2428587
Coding: 0309617
VCID: 2B55268A8904C2461E5-517C
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 216
Time Indication: 0
Date: 2005.08.26
Time: 00:00:35
Freeze Frame:
Voltage: 12.40 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 215
Time Indication: 0
Date: 2012.08.10
Time: 06:37:42
Freeze Frame:
Mileage: 655350 km
Count: 1109
Clock: 20:16
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4035
Coding: 11900
Shop #: WSC 06335
VCID: 78FFC9C658D2B9DEA37-4B00
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
1 Fault Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 285FD9869BF2E95EF37-807D
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309617
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 216
Time Indication: 0
Date: 2005.08.26
Time: 00:00:35
Freeze Frame:
Voltage: 12.40 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 215
Time Indication: 0
Date: 2012.08.10
Time: 06:37:42
Freeze Frame:
Mileage: 655350 km
Count: 1109
Clock: 20:16
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 93008 999 59057
VCID: 2A5B238E86FEDB4EE53-515E
2 Faults Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 130.0
Voltage: 13.60 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Time Indication: 0
Freeze Frame:
(no units): 21.0
Voltage: 13.40 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020605
Coding: 0000304
VCID: 316934E2AB28A896249-515E
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Time Indication: 0
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000411328
Coding: 0011877
VCID: 3A7B13CE765E6BCE953-5124
End --------------------------------------------------------------------
