When you purchase the tune, get the cable, download the software and connect to your car for the first time, the flashing server first does a scan of your car. It pulls down all the box/controller codes on the ECU side and then determines if a match exists. If not, you’ll get a controller not found message and the engineers will whittle something up for you, usually within 24-48 hours.
The only real difference in fuel is the rating method used. So our 93 premium is like 98 RON high test or whatever they call it in that portion of the world. Generally, on the premium “high octane” side, the U.S. has 91 and 93 AKI or (R+M)/2 but the two are equivalent. They just use a different means of calculating the octane rating.
When I process your order, it actually asks if you’re in N. America or ROW (rest of the world) and we’ve flashed a few people in your direction so you’ll probably be good to go.
How do they rate fuel in HK? What are your premium fuel octane ratings there, 98RON?
