will be interesting. The trap speed shows 131.3 but that’s a terminal speed, not a trap speed. So your actual trap was probably about 130.0 Definitely capable of a 10 second run however you’ll need about 1.5 seconds off your 330 foot time first (which is basically 1st and 2nd gear). Since you took about 2.7 seconds to hit 60 feet…which was probably about 35 mph…you only took 1.5 seconds to go from 35-60 mph. Pretty solid. If your 60 foot time was more like 1.7 seconds, you’d be looking at a 3.something second 0-60mph time which as we know is amazing.
How’d you launch the car? Does the file have launch control that you could use at some point? I’ll go review the pbox file to show you the other stuff like elevation.
Yeah, I will figure out the misfire and rich issue, it really fell flat around 7k and on the dyno it didn’t lose any power so I know it has more in it. When you figure out the slope I will figure out my goal for 1/4 mile on pump and meth.
This is all verified in the file, not the ‘best’ or the screen. This is legit (screen sometimes is optimistic…my 4.3-4.4 second 0-60 mph runs usually show as 4.2 on the screen for some reason.
On to Tweets…
60-130
7.62 seconds
Elevation
595 feet at start, 574 feet at finish
Distance to cover speed range
1102 feet
Slope
-1.90%
So that qualifies under the 6speedonline (perfectly…don’t they have a 2% slope decline maximum rule?) Unfortunately you shifted 2-3 in there while staying in 3rd might have made you quicker. Of course you were doing a quarter mile run at the time but just saying your 60-130 time will be better when you are testing for that.
12.08 @ 130.43 - that was your trap speed, not the pbox reported ‘terminal speed’ at the finish line
Elevation change
-26.3 feet over 1320 feet = -1.99% slope
***pbox reports MPH as terminal MPH (i.e. when you crossed the line) while tracks calculate the average of the last 60 feet of the track. So that’s what I did.
Oh ok, we’ll I’ve never done a log of a drag strip but there are some that look just like that road as far as a slight down hill… It is what it is, a roll out p-box run. I slipped the clutch at 3500 essentially. I’m hoping a 132-3 trap at 10.8x on pump then. I can take my rubber mats clothing and backpacks full of theatre stuff out. Almost 100lbs there. This was on Half a tank too. Should be right in the hunt then. I believe they accept 3%
looks like you left about 3 tenths on the table in shift time too (and more if you want to powershift the car)
so with a good launch, better shifting, there’s probably a really good time there. Not sure how accurate the 60 foot data is on the pbox. Primetime had 2.something 60’ data come out of his pbox, while the dragstrip said 1.7, so who knows how pbox is calculating it. Staging is very imperfect using a pbox.
