Which wires to jump to test AC pressure switch?
There are 3 conductors. Which ones do I need to jump?
I don’t remember there colors off hand. If you can take a picture. Or if you have a vag Com you can do a out put test that should help test that switch.
I need to get one.
Even an AC diagram for the car would be helpful right now.
I installed the new switch and it didn’t help. Still blows warm.
I also had a friend evac and charge the system with the correct amount. No dice.
Any ideas? The compressor is not running at all.
The first big thing is to check and see if there are any codes. You can also try to jump the compressor and test it there too Those compressor units fail very easily. It’s a common failure. You didn’t pull the AC at any point in the last 8 months did you.
I had the codes pulled BUT - I had been pulling fuses when troubleshooting, so I don’t know which codes are legit and which of them I actually caused during testing.
Saturday,21,March,2015,07:31:44:09152
VCDS – Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: WUARU78E77N900334 License Plate:
Mileage: 102670km-63796mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
      67 69 75 76 77
VIN: WUARU78E77N900334 Mileage: 102670km-63796miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0060
Revision: --H09— Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 05927 444 85878
VCID: 24475904E7F83F012A7-8071
3 Faults Found:
049508 - No Communications with HVAC Control Module (J301)
           U0164 - 008 -  - Intermittent
         Freeze Frame:
                Fault Status: 00101000
                Fault Priority: 0
                Fault Frequency: 1
                Reset counter: 255
                Mileage: 102335 km
                Time Indication: 0
         Freeze Frame:
                RPM: 776 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 94.0°C
                Temperature: 42.0°C
                Absolute Pres.: 1010.0 mbar
                Voltage: 13.716 V
005634 - Power Supply Terminal 30
           P1602 - 002 - Voltage too Low - Intermittent
         Freeze Frame:
                Fault Status: 00100010
                Fault Priority: 0
                Fault Frequency: 1
                Reset counter: 255
                Mileage: 0 km
                Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: -40.0°C
                Absolute Pres.: 0.0 mbar
                Voltage: 0.000 V
           P1923 - 008 -
         Freeze Frame:
                Fault Status: 01101000
                Fault Priority: 0
                Fault Frequency: 1
                Reset counter: 255
                Mileage: 102673 km
                Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 90.0°C
                Temperature: 66.0°C
                Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B55B2388A26F079EBD-807E
1 Fault Found:
        000 -  -  - Intermittent
         Freeze Frame:
                Fault Status: 00100000
                Fault Priority: 3
                Fault Frequency: 4
                Reset counter: 37
                Time Indication: 0
         Freeze Frame:
                Hex Value: 0x0000
                Hex Value: 0x4202
                Hex Value: 0x0024
                Hex Value: 0x018C
                Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6DD17C2027B23E49B59-5124
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D718C6037526EC9459-4AEA
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW:
Component: SDAR XM
Revision: Serial number: AUZ4Z7F6045940
Shop #: WSC 00000 000 00000
VCID: 2B55B2388926F079EBD-515E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
        000 -  -
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
2 Faults Found:
         Freeze Frame:
                Fault Priority: 0
                Fault Frequency: 1
                Reset counter: 255
                Mileage: 102335 km
                Time Indication: 0
         Freeze Frame:
                RPM: 779 /min
                Load: 20.0 %
                Speed: 0.0 km/h
                Temperature: 94.0°C
                Temperature: 42.0°C
                Voltage: 13.716 V
         Freeze Frame:
                Fault Priority: 0
                Fault Frequency: 1
                Reset counter: 255
                Mileage: 0 km
                Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Voltage: 0.000 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001W1XD
Coding: 0432607
VCID: 3C7781647F4867C1727-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 36TC8
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB4030B890DRÿ†63
Subsystem 5 - Serial number: B890DRÿ†6342DRB4030A1292Bÿ†63
Subsystem 6 - Serial number: A1292Bÿ†6352ARB4012C8621Eÿ†63
Subsystem 7 - Serial number: C8621Eÿ†6362ARB4012CB733Mÿ†63
Subsystem 8 - Serial number: CB733Mÿ†63729RB401201CF2Gÿ†63
Subsystem 9 - Serial number: 01CF2Gÿ†63829RB401201CF5Kÿ
Subsystem 10 - Serial number: 01CF5Kÿ
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 04441
Shop #: WSC 06335
VCID: 4487F98454B81F010A7-4AEA
1 Fault Found:
01304 - Radio
        49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 S HW: 8E0 920 981 S
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 05927 444 82792
VCID: 3D718C6067526EC9459-5124
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
        010 - Open or Short to Plus - Intermittent
01320 - Control Module for Climatronic (J255)
01304 - Radio
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
3 Faults Found:
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71E960503B8ADAA9911-4AEA
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H72 0110
Revision: 03S Serial number: AUZBZ7F2442448
Coding: 0309637
5 Faults Found:
00532 - Supply Voltage B+
        002 - Lower Limit Exceeded - Intermittent
         Freeze Frame:
                Fault Priority: 7
                Fault Frequency: 1
                Reset counter: 60
                Time Indication: 0
                Date: 2013.03.20
                Time: 00:43:35
         Freeze Frame:
                Voltage: 12.30 V
00446 - Function Limitation due to Under-Voltage
         Freeze Frame:
                Fault Priority: 7
                Fault Frequency: 1
                Reset counter: 60
                Time Indication: 0
                Date: 2013.03.19
                Time: 23:56:29
         Freeze Frame:
                Voltage: 10.70 V
                Mileage: 655350 km
                Count: 2708
                Clock: 11:19
00857 - CD Changer Unit (R41)
         Freeze Frame:
                Fault Status: 00100100
                Fault Priority: 5
                Fault Frequency: 10
                Reset counter: 59
                Time Indication: 0
                Date: 2005.08.26
                Time: 00:29:27
01316 - ABS Control Module
         Freeze Frame:
                Fault Priority: 5
                Fault Frequency: 12
                Reset counter: 58
                Time Indication: 0
                Date: 2010.03.24
                Time: 18:31:29
         Freeze Frame:
                Bin. Bits:     0000
                Mileage: 655350 km
                Count: 1602
                Clock: 07:40
01305 - Databus for Infotainment
         Freeze Frame:
                Fault Priority: 5
                Fault Frequency: 3
                Reset counter: 60
                Time Indication: 15
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4035
Coding: 11884
Shop #: WSC 06335
VCID: 78FF5D7458F08BE156F-4AEA
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
5 Faults Found:
00962 - Alarm via. Tilt Sensor
        35-00 -  -
01374 - Alarm triggered by Terminal 15
        35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver’s Side
        35-00 -  -
00956 - Key 2
        35-10 -  -  - Intermittent
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 05127 444 87830
VCID: 2959483080DAE269191-807C
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
         Freeze Frame:
                Fault Priority: 2
                Fault Frequency: 8
                Reset counter: 29
                Time Indication: 0
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309637
5 Faults Found:
         Freeze Frame:
                Fault Priority: 7
                Fault Frequency: 1
                Reset counter: 60
                Time Indication: 0
                Date: 2013.03.20
                Time: 00:43:35
         Freeze Frame:
                Voltage: 12.30 V
         Freeze Frame:
                Fault Priority: 7
                Fault Frequency: 1
                Reset counter: 60
                Time Indication: 0
                Date: 2013.03.19
                Time: 23:56:29
         Freeze Frame:
                Voltage: 10.70 V
                Mileage: 655350 km
                Count: 2708
                Clock: 11:19
         Freeze Frame:
                Fault Priority: 5
                Fault Frequency: 10
                Reset counter: 59
                Time Indication: 0
                Date: 2005.08.26
                Time: 00:29:27
         Freeze Frame:
                Fault Priority: 5
                Fault Frequency: 12
                Reset counter: 58
                Time Indication: 0
                Date: 2010.03.24
                Time: 18:31:29
         Freeze Frame:
                Bin. Bits:     0000
                Mileage: 655350 km
                Count: 1602
                Clock: 07:40
         Freeze Frame:
                Fault Priority: 5
                Fault Frequency: 3
                Reset counter: 60
                Time Indication: 15
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 HW: 8E0 907 273
Component: Reifendruck 3 H04 0110
Coding: 0062523
Shop #: WSC 02197 785 00200
VCID: 69D90830435A2269D91-5124
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020611
Coding: 0000304
VCID: 3169A050AB0A9AA9D11-5124
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000435763
Coding: 0011877
VCID: 3A7B877C767C59F160B-5124
1 Fault Found:
01304 - Radio
         Freeze Frame:
                Fault Priority: 5
                Fault Frequency: 1
                Reset counter: 157
                Time Indication: 15
End-------------------------(Elapsed Time: 07:21)--------------------------
Could these stop the AC from working all together?
FYI - my external temperature still displays on the gauges.
Jeff the codes you posted above would have some issues on the system working. But you said you pulled fuses. I would clear the codes and just check the HVAC codes. You can also do an output test in the HVAC module in vag Com. If you have issues figuring out how to do that let me know. I can walk you through that.
Thanks man - The problem is that I had a bud scan it for me. I don’t own a cable. I need to…
Nooowwww… my econ light stays on. Crazy. Waiting on a control module that I ordered.
Oh man. I don’t think it’s the module. The economy light just kinda raferms that.
Who knows… I had already ordered the module when the econ light was not coming on.
What does the Econ light usually mean for you guys?
It’s not the module your compressor is probably shot. The econ light generally comes on when the system isn’t working correctly. It can be compressor or fluid related.
I did a little more work with the vag-com. Looked like I had 1bar pressure on the AC system, which from reading online means it’s empty. I put the same crappy can (with gauge) on it and sure enough, it was way way low/emptyish. I went ahead and added enough so that vcds showed an increase. I checked it the next day and it was back to 1bar. I guess I might have “created” a leak by over pressurizing the system. Going to take it to a shop tomorrow to get sniffed.
That’s very possible. Let us know what you find. Usually they do a smoke test on AC systems. It works best.
He couldn’t get the compressor to kick in even after charging. He said that it’s throwing a code for the AC control module. I find it hard to believe that adding a little gas killed the module AND caused a leak.
He’s a well-known BMW Mercedes mechanic but doesn’t specialize in Audi. He sent the car home broken but didn’t charge me anything.
So I DO have this other AC module that I bought off ebay just in case… What is involved in recoding it? Any chance it will work correctly without recoding?
I’m with you. The module could have exploded but that wouldn’t cause a leak in the AC system. You could have two separate issues but I doubt that. The AC module isn’t a part you hear of going bad. You should be able too grab the coding from vagcom and just copy that code over if needed to too he new unit. You shouldn’t have to oleo recode it as long as it’s from the same body type.
Also it’s not helping that he didn’t give you too he one he actual codes. What’s the fault code in the module
I’m guessing it was this:
Also - is there a separate compressor relay - and if so, where is it found?
