Ya, aside from the question being asked was about an epl 600 HP car running 13’s which doesn’t at all match bt’s car which you reference in answering his question…you clearly helped clarify things for him.
Happy put ir best most of these companys ms paint you a nice dyno sheet.
The area of power is super tiny…thats why bt and all the other guys with a turbo too big for the csr are slower then stock from 0-60 even on race gas methonal lighter cars with huge exhaust and a str9nger clutch.
I have said im a fan of BT but his driving isnt the biggest issue its the fact h8s car makes no real hp till 5000 rpm…we can see thr dimwhitted b5 trolls popping in with dyno sheets to try and show you thats wrong…since you can load up a car on the dyno its a good way to make it look like it makes power down low…those guys posting dynos with that are some of either the dumbest or biggest frauds…
There is a reason the b5 is a joke now and its getting worse…over 5 years ago vast countvohn tuned went 134 11.4 with gt turbos and 24lbs of boost. Now it takes these guys stright alcohol full race gas and 30+ lbs of boost to do the same…BT is doing something different he has a single turbo so most of this doesn’t apply to him…still his set up makes big power but has a small power curve vs say a rs6r turbo or a supercharged 4.2
Pretty funny because 11.7 was with a 2.2 60’ and no nitrous… I haven’t actually used the nitrous at the track yet. Looking to maximize things without it first, then get some runs with it.
Really? Pretty sure my car is full weight And before my flywheel flew apart the other week I was doing some practice 0-60 runs and saw a few 3.6 second runs… what’s stock 0-60?
