So I’ve started on my journey to add wireless CarPlay to the existing MMI system and screen. No screen replacement at this time. I’m hoping to do this on the (relative) cheap with a unit I bought off of Amazon for well under $300 shipped.
Assuming everything eventually works, I’ll turn this into a DIY thread for everyone else.
While I’m waiting for the new updated RS Nav units to be released, I found a very cheap wireless mirroring system on Amazon, specifically the Carlinkit.
https://www.amazon.com/gp/product/B07S1M9XYB/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Before you go and order it, know that it did not work as delivered so a bit of a spoiler. But read on, there’s hope.
I believe they sent me the wrong wiring harness patch. I’ve sent them a ton of information so hopefully they have the correct harness. My was labeled Q5 but I believe the S5 (2013+) MMI is identical to the RS5’s.
This is what I received, from China, in about seven days.
The instructions were very poor and I practically needed a mangnifying glass to read the type. I ended up pulling the MMI unit out and took a bunch of photos. Thought this would be a good process to document for others. Note, the 2014 and on MMI is slightly different. I don’t know if the connectors on the back are any different from the 2013.
The main harness splice did fit. It essentially sits in between the MMI and factory harness and plugs into the Carlinkit box. It had two additional plugs coming off the splice however, and there wasn’t anything to plug it into. The kit also contained one additional USB/Video/Audio and wiring harness which didn’t have anything to plug into on the RS5 either.
This is the main electronic “box” which adds Apple CarPlay.
On the main box, they have a compatibility chart and dip switch chart. The unit came set up for a B9.
Here’s the back of the MMI unit with everything still plugged in. Good idea to take a photo to remind you of what goes where!
Completely unplugged, here’s a shot of the back.
I don’t know what each plug is for. I need to look over the wiring schematics and haven’t done so yet.
The violet, blue and green plugs are all single pin antenna-type plugs. The green one is not utilized.
The yellow and gray plugs, which are four pin male, are also unknown but I know at least one is the back up camera and I’m guessing the other is the front parking sensors.
The plug on the far right is an optical plug. Guessing this is how the sound signal is delivered to the amp. The big plug on the right is the main harness interface plug.
Closeup of the optical output plug.
This is the kit’s “splice” harness. It plugs into the back of the MMI unit and into the factory connector.
This plugs into the Carlinkit box and has a USB out. The rest really was of no use. Everything was labeled Q5 too.
Once it’s plugged in, you have these two plugs which have nothing to plug into. Has to be the wrong harness.
One end of the Carlinkit splice harness plugs into the Carlinkit box (plug on the left). Plug on the right is the USB and a series of power/ground wires for who knows what.
A few photos of the stickers on the OEM MMI unit.
It is VERY easy to remove the MMI unit with the right tools. You’ll need two of these which can be found on Amazon or even, at times, Walmart. They’re cheap too:
I believe this is the splice harness for the rearview camera.
This is the Bluetooth transmitter making it wireless. You basically conceal this somewhere behind the dash where it isn’t shielded by metal. I haven’t gotten that far yet. Want to make sure it’s working before I decide to take the glove box out. With that said, it appears there’s enough room behind and below the MMI for the Carlinkit box and wires.
I’ll post updates once I get a reply back from the vendor. Hopefully this’ll work and it’s a nice, cheap alternative stopgap until the new RS Nav units are released.
Phil Miller, from Miller’s Motorsports in the UK was nice enough to send me a quick screen shot of the factory service manual pin labeling diagram for the MMI.
I’m rummaging through the FSM trying to find the corresponding numbers to see what each does.
