100 vs 104 race gas
I think I might try and burn way down today, add the ten gallons of 102, and drive it to the strip burning the 102 with the REVO SPS set at position 4. It’s a distance of about 65 miles. I doubt if I’ll have nearly as nice of a DA, especially a negative one, but it looks like a chance of rain is diminishing so I’m going to give it a try.
You might have glazed it. Just drive it normal for a little.
Sounds like clutch isn’t gonna last much longer for track days/104 file though.
Auditude’s is also on it’s way out. It’s fine for day to day. Doubt it will last another sticky track launch though.
What is the name of track you are going to?
Also I would add very little 102 for drive down. Maybe 2 gallons. Run that to empty and refill at track or right before track again with 2-3 gallons. You don’t want too much fuel for your runs. 10 gallons is too much.
Even if you burn 2 gallons on your way down… You don’t need 8 gallons for your passes.
Also if you aren’t seeing ~1.7s 60 ft times - lower your tire pressures. They might be too high.
Thanks and thats my plan, drive normal and avoid the track.
Anyone installed an aftermarket clutch on these cars? Maybe the eurocode one?
Jhm also has a nice setup.
I just checked them out.
Does a stage 2 require something other than the stage 1 clutch upgrades? Eurocode stage 1 is rated at 450ft/lb and I don’t think stage 2 cars even make that. I don’t see what stages JHM clutches are rated at but they are significantly cheaper than eurocode. I just want something that will hold at the track and retain somewhat stock feel as I have no plans to make this into a bonafide race car.
I had JHM parts on my old B7 S4 and was more than happy with them.
Great idea. Don’t do what everyone told you. Try something different.
No more War Room pls ;D
Seriously, if you are doing that just to be safe that you don’t run out of fuel, then at least run it down around your neighborhood, then put 5 gal in, run it to 0 miles, and put the other 5 gal in before you head to track, or something like that. …
Ad
Understand about the weight, 8 gallons, and concur.
Why would anyone buy a Eurocode clutch? Do people even run these?
The last person that had that clutch was paperfag and he promised us great things…he hasn’t been seen since then, I actually think it was because it failed or was slipping pretty quickly after install.
While I can’t speak on JHM products for the B8, I can say that their B6/7 S4 RS4 products have always been amazing…I wouldn’t expect anything different for the B8. I would never buy a Eurocode product, they have headers they have never shown testing for and same goes for their clutch.
OK
There is a used ec clutch + flywheel on the zine and the guy now has a JHM clutch flywheel setup so that may say something? I only asked about EC because that the only company I knew making them. I had no idea JHM made a kit as well. I do have EC ak and sways and have been happy with them but those are only bolt ons.
If I were to do a new clutch is a new flywheel necessary?
I’ve also been happy with my sway bars, links and AK. They provide the b8 with decent product support, though I can see the headers issue. Wish JHM did more for this platform…I like the rear rotors I bought.
It’s not necessary, unless it has many hot spots, or is warped to hell from many hard launched miles. But, the way JHMs flywheel setup is, which is fucking awesome, just buy their lightweight flywheel, which has a replaceable friction disc. Then when it’s time for the next clutch, you won’t need a new flywheel ($1299 stock), simply replace just the fiction disc and gtg!
Consider that and the lighter weight, makes it the best available, most likely in the world. Huge props to JHM for continually making high quality upgrades for Audi.
Ad
Sorry missed your first question, http://www.coastalplainsraceway.com/. Jacksonville NC. Gates open and 12:00, runs from 12;30-4;30.
http://tapatalk.imageshack.com/v2/14/11/08/a6dae06ebe39c6a8f8d72e7db9ed4603.jpg
Not too bad for rest of day.
Agree, the last time I was out there I was dealing with about 2000 ft. DAs. Thanks for the info. Jacksonville airport is only a few miles away and I’ll be able to get current data very easily.
I have the JHM flywheel with the hybrid clutch, which is ceramic on one side and organic on the other. I’m quite happy with it. JHM did the install for me, so I know it was done right.
FWIW, below is my best time sheet on my car, done back in May. Went again in June but times almost identical. The 60 ft times aren’t very good. Used launch control and this was with an APR tune. Also, meth injection was not installed at that time. DA about 2000 ft. I’m car 22, obviously?
http://i.imgur.com/oxebKkW.jpg
what’s interesting is that you might be the only guy to be able to run REVO somewhat safely since you’re spraying alcohol at it. The REVO pump parameters approach the other tuners’ race file parameters. Running pump + meth is effectively running race fuel, so that works well.
Your time won’t be considered a pump time though…it will be pump+meth which is looked at as effectively race.
