Hey everyone. First post here on AR - I’ve been talking with Ron and Mike about this issue and in general performance variations among cars and the reasons… Eventually I want to go Stg2 myself…
Posting here in the hopes that the plots I’ve generated might help the discussion, and I have some questions I’m sure the folks here can answer…
I’ve plotted up data from my stock 2013 S5 on 93, one of Ron’s runs on the 100 program back in oct, Mike’s run, kappax12’s logs, and Skywagon’s data. Everyone except me is stage 2 - but there is a mix of 91/93/100 octane – and I thought the comparisons/contrasts were interesting… At any rate :
http://i616.photobucket.com/albums/tt241/jgreat_bucket/S5/Logs/stock_vs_stg2_5_zpsf5069af2.png
I’m new at this, but things I noticed :
- Mike/Skywagon’s timing is petty similar - Ron is in a different league, and the stock car is higher than the stage 2 which is no surprise. kappax12’s is pretty low. I believe this from the 91 program before he switched to 93.
- absolute manifold pressure is different among the stage 2 tunes, but the combination of MAP and IAT makes the air density pretty much the same - and that’s more or less confirmed by the MAF readings between all of the stg2 cars being pretty close.
- Mike’s IAT are well above the others - partially due to ambient conditions, and maybe also due to the lack of any kind of upgraded cooling. On IAT’s - keep in mind that Mike,Ron,Sky’s logs were from just 3rd gear from a run through the gears, where my stock and kappax12’s were a single gear pull from low to high RPM. I think that’s the reason for the shape difference.
- Nice visual of the boost difference between a stock and S2 car at low rpm between kappax12 an me… about 500 rpm for the same boost level…
I didn’t plot RFP_AV since it’s closed for all of the S2 cars, and opens up big time on mine (about 20% at 6000 rpm - again no surprise). Also didn’t plot timing pull since it’s sort of usual - blips to -4 or so for most everyone, except Mike- he had -5 to -4 above 5500 rpm.
So - questions for those who know :
The fact that Sky’s and Mikes MAF and timing seem to be very close makes me think they are both performing as expected for these parameters? Mike had more timing pull - likely due to the IAT’s?
The IAT from Ron’s vs. Mike’s runs and the same manifold pressure means he has 7.5% lower density in the combustion chamber (132F vs 180F is 639.6R vs 591.6R so 591/539 = 92.5%). Does that mean he would be down just 7.5% on power if the timing and AFR was identical, or is there more to it than that?
IAT’s … at what point does high IAT mean timing is reduced. Is it a continuous function of the maps or is it just a function of sensing knock? Both? How close are tunes usually to the stated octane - if you have 92 gas on he 93 program is it going to pull timing or is that within the headroom?
At what point does AFR start affecting power output? These cars will dump extra fuel to keep things cool, right? That extra fuel “soaks” up heat and keeps EGT’s down which leads to lower output?
Is the difference in timing between Mike/Sky’s curve and kappax12’s typical for 91 to 93, or is that larger than expected? Is there any way to estimate how much power say 5 deg of timing costs?
Thanks - looking forward to gaining knowledge here on AR…
Jim
