BenSTlie said it on AZ. I wonder if Arin will chime in one how easy that is. Rigging I’m sure in his mind entails all lines being connected. Like you brought up though…software still needs to be reflashed and “hopefully” the changes to the fuel system will allow the car to run properly NA. Also, forget the fact that you’ll have Heat exchanger/coolant expansion tank lines to hide. Fuel rails will proabably need swapped back to stock.
[quote]APR’s supercharger system varies greatly from the OEM intake manifold design, and for fitment’s sake, the factory high pressure fueling system must be modified. The fuel rails and other high pressure and low pressure direct injection fuel lines are replaced with new, low profile, OEM parts. All OEM safety equipment remains intact.
Extra vacuum lines
Pulley and Belts swapped back out
I’m sure if I dug into it…it’s not a 2-3hour fucking RIG JOB!
I’m sorry but these idiots can’t be serious about going back to stock to get it inspected, most end users of this product don’t have the capability to convert back to stock in their garage. Even a guy like myself that sould, sure as fuck wouldn’t want to every damn year.
This is honestly just more GOLD from an idiot like BEN, who in their right mind has him install their $20k supercharger kit? Same goes for everyone else acting like you just swap the manifold on and off. I know it’s quick to take off and put back on a top mount once it’s in place, but people are somehow forgetting everything else that routes to the new top mount charger vs the stick IM.
