Ya, i do want a decent uncompromised ride thats why i went 18. May still end up with a set of cheap 19 or rebuild a set i already have in 19. Just need a barrel fixed and/or replaced.
17" with fat tires is the way to go
Well my stock wheels are 18 with 245/45. I compomised some but not much. 265/40 tires mounted on 18x10" wide wheels…pretty darn close to stock overall dia (.4 less). 275/40 would match perfect but worried about rubbing. Picking up the mounted setup in a few minutes after work actually
I do remember your 17" ssr with meaty tires. Looked great!
Repeat
Also ordering a set of IPP arms that at level 2 are same ride height at stock 402. Level 1 is about 10-12 mm lower, level 3 and 4 settings allow for noticeably higher clearance, I forget the actual measurements on height though.
Repeat
happy2Repeat
Yaya
Tires mounted. Shop paid attention and took care not to f em up. Has happened before. Needless to say i wasnt happy
http://tapatalk.imageshack.com/v2/14/10/30/f3fcc8f64b44a0dbbc64703791f1e034.jpg
http://tapatalk.imageshack.com/v2/14/10/30/ae2606f8c9f17a5f09b6f12a1c52ed89.jpg
Might go 275 next depending on clearance needed or allowed. These 265 are heavy enough, jeesh. Good thing wheels are light
http://img809.imageshack.us/img809/1005/img3051i.jpg
BAM! I’m gonna try to mount them on my Golf R at some point, that should be entertaining
Yep. Those are them. Ha! Looked great. Tire size?
255/40/17 Hankook RS3s… those run more like a 275 width though
sourced a set OEM mudflaps new unused in box for 1/2 price
http://www.ecstuning.com/Audi-All_Road--2.7T/Exterior/Body/Splash_Guard/
Always great to nab the parts you need for cheap.
Trans service scheduled for tuesday and hotchkis sways going on over weekend.
Went ahead and ordered up the s45 whispbars
If it’s not too late. See if you can get a sample of the old transmission fluid. All the people I have helped I take a sample of the old and compare it to the new. It helps show the condition of the transmission
Yep. Already mentioned i wanted to see where it was at. Ill make sure to do so on tuesday.
Update on rain tray. Rained not poured but still raining and my floor board is dry. Hopefully my cleaning, refitting and sealing has resolved the issue. So far so good though at this point.
