Closer
DROP it…you are wrong and no one cares
Wheel spin effects ET, not MPH…in fact your MPH should be higher with wheel spin. You also need to understand some wheel spin is good with an AWD and judging by your 60’ times you are getting off the line pretty great. If we also compare that to Saki’s example of your 330’ time only being .17 seconds off the quickest car on the list that means you are doing great the first half of the track.
A month ago you were slamming the brakes before you were through the traps…this week you want to claim you spun until the 1/8th mile.
Your problem is you can’t admit screwing up again. You fucking hacked a hole in your hood, added meth, switched tunes and still can’t get the ET/MPH plenty of other S4s have seen. We told you to be patient and if anything go with GIAC. How is all this working out for you? You put APR on blast because of your tune.
*I think it’s time you ask Revo why your trap sucks and your tune blows after the 1/8th mile in your 1/4mile testing.
I know you have a 2014…blahblahblah, but just look at the ETs and the trap speeds. Your ET is great for your LOW trap and your 60’ is great. Even if you spun your trap should be higher. Your trap is pretty much the same for every one of your runs.
gringoloco2000 B8 S4 3.0T Manual 100 APR S2 stock/AWE TVSr1320 12.23 112.91 1.74 Strat intake, lightish wheels
Auditude2.0t B8 S4 3.0T Auto 93 REVO stock/AWE TVSr1320 12.27 112.11 1.82 Roc Euro intake
rynurz23 B8 S4 3.0T Auto 100 APR S2 stock/Stasis TVSr1320 12.28 113.25 1.83 AWE intake, APR CPS, LW wheels
Tribe B8 S4 3.0T Auto 93 REVO stock/stock TVSr1320 12.28 113 1.79 AWE intake
Jones2012S4 B8 S4 3.0T Auto 94 GIAC S2 Eurocode catless 12.28 112.99 1.76 RocEuro Intake
clochner B8 S4 3.0T Auto 93 APR S2 stock/Milltek TVSr1320 12.3 112.89 1.74 RocEuro intake
clochner B8 S4 3.0T Auto 93 APR S2 stock/Milltek TVSr1320 12.32 111.62 1.73 APR 2 intake, LW wheels/winter tires
theKB B8 S4 3.0T Auto 100+ APR S2 stock/stock TVSr1320 12.34 113.13 1.85 custom intake, LW wheels
saxoff B8 S4 3.0T Auto 93 EPL S2 stock/APR TVSr1320 12.35 112.24 1.79 APR pulley, Injen Intake, LW wheels,
Joneze93tsi B8 S4 3.0T Auto 100 APR S2 stock/APR TVSr1320 12.38 112.63 1.88
Sky, You really aren’t listening to anyone and I’m not sure why… I hate to say it but the Revo tune just isn’t cutting it… The only reason you are improving is the damn dsg tune which allows the car to rev to 7k… Not sure how/why you don’t understand this??? Your 60ft time/330 is fine which has already been pointed out… The car sucks on the top end for some reason, I believe it’s the tune… Even if you did spin and lost say 5 hundreths or so your mph is what sucks… I trapped 116+ on stage I, with a shitty 60ft time but close to the ET… We’re trying to help you just don’t seem to accept things and again not sure why?
http://www.audiworld.com/forums/s4-b8-platform-discussion-134/so-back-dragstrip-round-8-a-2794888/
In the grand scheme of things, 12.0 at 112.x is a fantastic time. It might not be the best theoretically possible time and he’s left something on the table. But I don’t think he has faulty software or a defective tune. These are enviable numbers for a sports car platform from 2009.
Agree, i wouldn’t call it a faulty tune, but a tune that can use a revision to be on par with the top contenders.
With what your saying it’s hard to think If you didn’t spin the car would have faster but mph aside that’s not necessarily true. If you didn’t spin the car might have launched harder but not faster. When care bite hard they slightly bog down for a second as they need the power curve to push the car to come in. Thinking that spinning is slowing you down is normal but spinning doesn’t mean the car isn’t accelerating and it doesn’t mean that there is going to be a measurable difference.
Everyone is saying the same thing. Your assuming no spin will equal faster that’s not always true. If done right wheel spin can help mid level hp cars acceleration.
Regardless of what you or anyone thinks the facts are there to make sense
Your 60’ and 330’ don’t show signs of lost acceleration at the start.
Something appears to be off as the mph was lower then expected.
I would say shut off the Meth that slowed the car down. In those temps it’s almost not needed.
Well a few on vendorzine get it…
Pete ftw… Lol.
http://www.audizine.com/forum/showthread.php/628739-REVO-to-1-4-Mile?p=10337928&viewfull=1#post10337928
AZ is what I imagine a physics class in North Korea is like. The rest of the world has a slightly more evolved understanding of the science.
AW is stuck in pre kindergarten. The top 3 threads are about how to turn the headlights on.
Top 2 unless you don’t count the Lambo door thread.
lmao, so gay.
This should be a banner add that runs across the top. Great post it’s crazy true
I’m not sure if I’m one of the ‘knowledgeable’ guys, but I’m definitely no longer trying to help. You can’t help someone who doesn’t want to be helped
This situation is comical. Someone gets an idea in their head (probably listening to people who know nothing about these cars) and then doesn’t want to listen to anything/anyone else. Not the fastest B8 S4 owners. Not the seasoned dragstrip veterans on the site. Not the guy who has entered and analysed hundreds of 1/4 mile times from 10 different Audi platforms.
So, let him be slow. Yes skywagon, it’s your wheelspin that is causing your 5 mph trap speed problem. Good luck addressing it. Maybe wider tires?
Agreed. It’s pretty clear he doesn’t want to and/or know how to be helped.
315s in the rear should help, Sky. Maybe a drag compound too.
I like one of the AZ recommendations…
“You need to make your hack-a-hole BIGGER”
LOL!
Mickey Thompsons.
Times are good, but could be better.
You did say that you had meth on? You do realize that with 100+oct, running meth, especially in the cold, dense air, will be to high of a mix and hurt timing? I believe Jeff had this issue when trying out too high of an octane mix. ?.
This could definitely be hurting your topend speed, where timing matters most.
Ad
is it just me? I don’t think he was asking for help, just giving us an update.
that went out the window as soon as he started on the whole wheel spin thing
LOL exactly.
I think it is something everyone takes personal. They have all tried to help and almost every step they kinda have to push some sense into Skywagon. Not that he isn’t smart but there is so much information coming from so many different directions. It cam be a lot to take. Nobody wanted to see him walk blindly getting frustrated at the wrong things
