So earlier this afternoon, I did a 3rd gear WOT run and shifted into 4th and continued the WOT for a little bit and then let off, switched into 6th and then my clutch pedal wouldn’t come back. It was still engaged, I was able to pull on to the shoulder, at which point I continued trying to play with it but the pedal still wouldn’t come back up. I went into neutral but couldn’t get back into gear (the pedal was still down). I then pulled the pedal back with my hand and I was then able to start using it again. I therefore merged back onto the highway and it seemed ok again.
Then, 20 minutes later I stopped for lunch for about an hour. After lunch, someone else drove the car briskly. The other driver didn’t notice any issues. I took the car back and 20 minutes later of more brisk driving, the problem was starting to slowly come back (I could feel the clutch pedal begin to not come back as quickly as it should although it never got stuck like the first time).
What could cause this? A bad slave cylinder? Low pressure in the lines?
Thanks.
