why are we blaming the JHM hardware when we haven’t determined the cause for those guys? JHM sends the clutch flywheel and pressure plate but speedetc. replaced other supporting parts and resolved his issue. Did you miss that post? axel and madison have yet to do what speedetc did I believe
[quote]has to be something but how many cars are you hearing about with issues related to the jhm clutch … even those guys from England were having issues.
I thought horsepower received the full kit but didn’t install it all…he wanted to just use the clutch or the clutch and flywheel, but not the pressure plate, (or something like that) so his issues may have something to do with that. He will chime in eventually.
[quote]i think you are right maybe i can just stick to a part that is reliable ie the intake manifold spacer which from what i heard which may not be true is made by 034.
no idea how that applies to this thread
[quote]i like the whole idea around the lwfw and was/potentially am thinking about getting a stg 3/4 with lwfw from jhm but it does scare me hearing these issues.
ask yourself a question - why are people buying these JHM clutches (or sachs or loba etc.)? Is it because the clutches on these cars just eventually die? So are you scared of the stock clutch? Mick’s stock clutch was destroyed at like 20,000 miles. Does that scare you? Better get that thing out of your car.
maybe just read the thread or other info on the products.
p.s. the ironic part is that about a dozen posts in this thread were made by guys with the clutch and no problems. There are a few hundred other people with the kits and they’re working flawlessly. Of course the squeeky wheel gets the grease, whether it’s a legit complaint or not. And you’re scared.
