Hi Ed could you send me pictures of what I circled. Thank you
I will try and get you something today.
Ed
Ok thank you very much ed
How do you attach a PDF to a post?
Ed
Ed,
Hit the reply button Then in the reply box you will have the area you type in and then just above that you will have your options for reply. The upload button is the 7th tab over. Click that.
Tried that. When I try to attach a PDF, it says not supported file type (it only takes image type files).
Ed
Let me look further and get back with you. Give me a few min.
Obviously you can take a screen shot of the info. Then drag the picture into the post by right clicking and dragging the picture. You don’t even have to click the load button for that.
I think there is way to load PDF files. I just have to remember how to do it.
No problem. I emailed the doc to him.
Ed
Thanks Ed I received it and today’s my 18th birthday
Give loading anything PDF wise a try again. It works for me. I just think it needs to have pdf in the file name.
Sprawwl. Happy bday to you.
sounds like Ed was able to help. I saw a few codes for the brake system. I don’t know how much this will help but I found this in some of my old files.
Now I have an Upload Icon, it used to be a picture icon. That will work!
Ed
So it turns out it was a relay for the computer that was burned out and that had to of been burned out for year and got worse. I changed it the car doesn’t cut off but when it does which is rare I can immediately turn it back on unlike before of me having to wait an hour for it to start
I’m still getting the terminal 30 low voltage with o2 sensors working or not but I seem to notice it’s somehow connected with high beams so when the car starts to act up which is when it goes low voltage the passenger side high beam will flicker if I use it and the esp light will come on which I assume means it’s not getting enough power for it to work
It only acts up whenever the car warms up so I’m thinking some of relay or could be the computer will I’m going to change because I don’t trust the wires jumped directly into board instead of the pins
I haven’t read back through but you have confirmed all grounds are good?
Ed
I believe so these are the only grounds right? And it only seems to run rough after you drive it for a bit but longer it’s off the better I honestly don’t know
Actually if you could can you see me a diagram or picture of all the ground points on the car?
Here is everything I could find on grounds:
- Doc with a bunch of info:
C6_S6_Ground_Locations.pdf (2.2 MB)
- Doc with pics from other parts of the Bentley:
C6_S6_Ground_Locations_1.pdf (455.1 KB)
Ed
