You can’t swap out ECU units. As they’re tied to the car Via the vin and immobilizer.
If you’re JHM tuned contact them they can help clone your ECU if you wish to put in a new one.
As for the Ross Tech scan. Just copy the error codes and paste them in.
The twin ECU system for the S6 and S8 have always had error codes for no coms. It just depends on what codes.
Yeah I’m was going to get a programmer to come once the ecu I ordered for 125 comes next week. I’m not jhm tuned. I had the car started for an hour now and it’s running smoother it seems to be somewhat working
Clearing codes and then letting the system adapt after you do it a big must for these cars.
The fuel trims have a wild swing rate you need to let them adapt. that takes time
I did I’ll send the codes when I get back home to the car
01-Engine – Status: Cannot be reached 1100
02-Auto Trans – Status: Malfunction 1010
03-ABS Brakes – Status: Malfunction 0010
05-Acc/Start Auth. – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
08-Auto HVAC – Status: Malfunction 0010
09-Cent. Elect. – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
11-Engine II – Status: Cannot be reached 1100
31-Engine other – Status: Cannot be reached 1100
15-Airbags – Status: Malfunction 0010
16-Steering wheel – Status: Malfunction 0010
17-Instruments – Status: Malfunction 0010
19-CAN Gateway – Status: Malfunction 0010
36-Seat Mem. Drvr – Status: Malfunction 0010
37-Navigation – Status: Malfunction 0010
4F-Centr. Electr. II – Status: Malfunction 0010
53-Parking Brake – Status: Malfunction 0010
55-Headlight Range – Status: Malfunction 0010
56-Radio – Status: Malfunction 0010
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: Malfunction 0010
6C-Back-up Cam. – Status: Malfunction 0010
76-Park Assist – Status: Malfunction 0010
77-Telephone – Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09— Serial number:
Coding: 01050009190F0160
Shop #: WSC 08101 444 53918
VCID: 221DE3E888C6D8ABB97-8076
7 Faults Found:
000313 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114279 km
Time Indication: 0
Date: 2006.03.15
Time: 23:15:20
Freeze Frame:
RPM: 1299 /min
Load: 16.9 %
Speed: 60.0 km/h
Temperature: 89.0°C
Temperature: 39.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114279 km
Time Indication: 0
Date: 2006.03.15
Time: 23:15:20
Freeze Frame:
RPM: 1299 /min
Load: 16.5 %
Speed: 60.0 km/h
Temperature: 89.0°C
Temperature: 39.0°C
Voltage: 13.970 V
001672 - ECM Power Relay Load Circuit
P0688 - 002 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 114325 km
Time Indication: 0
Date: 2006.03.16
Time: 00:49:34
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 30.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 0.000 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 114361 km
Time Indication: 0
Date: 2006.03.15
Time: 12:15:57
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 30.0°C
Voltage: 0.000 V
P1653 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 114361 km
Time Indication: 0
Date: 2006.03.15
Time: 12:19:28
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 30.0°C
Voltage: 0.000 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114365 km
Time Indication: 0
Date: 2006.03.16
Time: 04:14:40
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 29.0°C
Voltage: 11.303 V
Readiness: 0110 1101
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0010
Revision: --H01— Serial number: 0087899
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2F3B1ADCCB1465C3269-807A
3 Faults Found:
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 114325 km
Time Indication: 0
Date: 2006.03.16
Time: 00:49:32
Freeze Frame:
RPM: 1344 /min
RPM: 1280 /min
RPM: 832 /min
(no units): 3.0
(no units): 17.0
Temperature: 124.0°C
T.B. Angle: 60.0°
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 114325 km
Time Indication: 0
Date: 2006.03.16
Time: 00:49:32
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114325 km
Time Indication: 0
Date: 2006.03.16
Time: 00:49:40
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
VCID: 313F1CA4DD20733330D-8064
5 Faults Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 120
Reset counter: 226
Mileage: 114223 km
Time Indication: 0
Date: 2021.01.10
Time: 14:26:58
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x0194
Hex Value: 0x00FF
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 187
Mileage: 114365 km
Time Indication: 0
Date: 2006.03.16
Time: 04:15:39
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x4082
Hex Value: 0x0013
Hex Value: 0x8590
Hex Value: 0x00FF
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:02:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0282
Hex Value: 0x0013
Hex Value: 0x4489
Hex Value: 0x00FF
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 226
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:10:59
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0028
Hex Value: 0x019A
Hex Value: 0x00FF
02083 - Message for Delay Request
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 114365 km
Time Indication: 0
Date: 2006.03.16
Time: 04:15:39
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x4082
Hex Value: 0x002B
Hex Value: 0x0590
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000481449
Coding: 0000007
Shop #: WSC 06402 785 00200
VCID: 6393A6ECD75C91A3F21-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
4 Faults Found:
00263 - Transmission
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:00:15
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 187
Mileage: 114361 km
Time Indication: 0
Date: 2006.03.16
Time: 17:03:54
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:08:49
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 393FP067500038
Coding: 0010003
Shop #: WSC 02335 785 00200
VCID: 323D13A8D826482B497-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000467789
Subsystem 3 - Serial number: 0110.07.060000000100011443ÿ
Subsystem 4 - Serial number: 011443ÿ
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 212
Mileage: 114223 km
Time Indication: 0
Date: 2021.01.17
Time: 09:16:40
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030142529
Coding: 0524330
VCID: 5BE39E0CEF2CA963BA1-800E
9 Faults Found:
01844 - Control Module for Fresh Air Blower (J126)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 11:54:15
Freeze Frame:
Temperature: -70.0°C
Speed: 0.0 km/h
(no units): 255.0
(no units): 255.0
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 179
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 11:54:20
Freeze Frame:
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 11:54:20
00787 - Temperature Sensor in Fresh Air intake duct (G89)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 11:54:20
Freeze Frame:
Temperature: 29.0°C
Speed: 0.0 km/h
Voltage: 13.40 V
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 180
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 11:54:22
Freeze Frame:
Voltage: 13.30 V
(no units): 210.0
(no units): 255.0
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 179
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 11:54:22
Freeze Frame:
Voltage: 13.30 V
(no units): 222.0
(no units): 255.0
00739 - Coolant Circulation Pump (V50)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 216
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.16
Time: 23:34:32
Freeze Frame:
Temperature: 24.0°C
01854 - Heated Seat; Front Right (Z46)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 114291 km
Time Indication: 0
Date: 2006.03.15
Time: 23:33:12
Freeze Frame:
Temperature: 31.0°C
008 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 187
Mileage: 114361 km
Time Indication: 0
Date: 2006.03.16
Time: 17:02:05
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0115121
VCID: 303919A0D62A7A3B3F3-8064
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
5 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 215
Mileage: 114220 km
Time Indication: 0
Date: 2006.03.15
Time: 12:01:00
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 112352 km
Time Indication: 0
Date: 2006.03.25
Time: 18:43:00
02746 - Bulb for Daytime Running Light; Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 112340 km
Time Indication: 0
Date: 2020.09.28
Time: 09:25:00
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 112352 km
Time Indication: 0
Date: 2006.03.17
Time: 17:37:00
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 16
Reset counter: 215
Mileage: 114220 km
Time Indication: 0
Date: 2006.03.17
Time: 21:13:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 270BF2FCEFE43D83EE9-8072
No fault code found.
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F2029645
Shop #: WSC 00000 000 00000
VCID: 2809F1C0EEFA32FBE73-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 222
Mileage: 98432 km
Time Indication: 0
Date: 2006.03.15
Time: 12:18:54
7 Faults Found:
012871 - Oxygen (Lambda) Sensor B4 S2; Heating Circuit
P3247 - 004 - Open
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 114328 km
Time Indication: 0
Date: 2006.03.16
Time: 07:55:09
Freeze Frame:
RPM: 761 /min
Load: 23.1 %
Speed: 14.0 km/h
Temperature: 77.0°C
Temperature: 27.0°C
Voltage: 13.843 V
012823 - Oxygen (Lambda) Sensor B3 S2; Heating Circuit
P3217 - 004 - Open
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 114328 km
Time Indication: 0
Date: 2006.03.16
Time: 07:57:05
Freeze Frame:
RPM: 1464 /min
Load: 14.5 %
Speed: 69.0 km/h
Temperature: 88.0°C
Temperature: 25.0°C
Voltage: 13.716 V
000025 - Bank 2: CMP Sens 4 (G301) / Engine Speed Sensor (G28)
P0019 - 002 - Incorrect Correlation - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114340 km
Time Indication: 0
Date: 2006.03.16
Time: 08:21:28
Freeze Frame:
RPM: 640 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 105.0°C
Temperature: 47.0°C
Voltage: 13.208 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 114361 km
Time Indication: 0
Date: 2006.03.15
Time: 12:15:57
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 30.0°C
Voltage: 0.000 V
P1653 - 001 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 114361 km
Time Indication: 0
Date: 2006.03.15
Time: 12:19:28
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 30.0°C
Voltage: 0.000 V
049717 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114365 km
Time Indication: 0
Date: 2006.03.16
Time: 04:15:39
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 22.0°C
Temperature: 30.0°C
Voltage: 0.000 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7G AIRBAG AUDI8RH29 0400
Revision: 01H29000 Serial number: 003BMD000K0Q
Coding: 0014151
Shop #: WSC 08159 444 85931
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME107F3E2FI
Subsystem 3 - Serial number: 6342CSME107E082B5
Subsystem 4 - Serial number: 6352QSME0F2E263BU
Subsystem 5 - Serial number: 6362QSME1037084FG
Subsystem 6 - Serial number: 63734SME0E69353DB
Subsystem 7 - Serial number: 63834SME11581043P
2 Faults Found:
00532 - Supply Voltage B+
02095 - Component Protection Active
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026061890037
Coding: 0012141
Shop #: WSC 02323 785 00200
VCID: 6695BFF8246EE48B15F-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
2 Faults Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 47
Reset counter: 255
Mileage: 111614 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 255
Mileage: 111614 km
Time Indication: 0
Date: 2019.09.26
Time: 06:27:47
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 980 Q
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5H337R576
Coding: 2129263
Shop #: WSC 08101 067 57207
VCID: 2313E6EC97DCD1A3B21-8076
3 Faults Found:
00771 - Fuel Level Sensor (G)
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 95
Reset counter: 220
Mileage: 112343 km
Time Indication: 0
Date: 2020.09.28
Time: 00:44:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:08:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Reset counter: 187
Mileage: 112566 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:07
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B067038018
Coding: F5D5DEF7307A06
Shop #: WSC 02334 785 00200
VCID: 6C81CDD03A82DEDB43B-8038
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:00:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 187
Mileage: 112566 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:06
01342 - Engine Control Module 2 (Slave 1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 187
Mileage: 112566 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:07
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FACE4CD4083B3E0D-8034
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 108796 km
Time Indication: 0
Date: 2019.03.26
Time: 16:11:32
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381FK067502811
Shop #: WSC 08101 444 83282
VCID: 2E0507D8CC1E6CCB2DF-807A
1 Fault Found:
02445 - Disk Drive Initialization Error
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 111626 km
Time Indication: 0
Date: 2006.03.15
Time: 15:12:23
Freeze Frame:
Hex Value: 0x4418
Hex Value: 0x2ED7
Hex Value: 0x4656
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: 2C010DD0FA021EDB03B-8078
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01015926010000
Coding: 4618269
Component: LIN BACKUP HORN H02 1301
4 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 187
Mileage: 85830 km
Time Indication: 0
Date: 2016.01.19
Time: 07:52:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:00:27
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 28
Reset counter: 96
Mileage: 112353 km
Time Indication: 0
Date: 2006.03.16
Time: 14:25:06
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 187
Mileage: 112566 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:05
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000008417
Coding: 0000026
VCID: 2517F8F499E82F93DC5-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000030638
Coding: 0012014
VCID: 5EE59718FC3EBC4BDDF-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 187
Mileage: 112564 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:00
Freeze Frame:
Voltage: 12.400 V
Temperature: 57.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04—
Coding: 0008022
Shop #: WSC 02324 785 00200
VCID: 1F1BEA1CBBB4F543969-804A
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 10
Reset counter: 187
Mileage: 114216 km
Time Indication: 0
Date: 2006.03.15
Time: 17:12:56
Freeze Frame:
Voltage: 10.87 V
Count: 241
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 290FF4C4F5F00BF3F8D-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
6 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 109240 km
Time Indication: 0
Date: 2019.04.23
Time: 17:51:46
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 27
Reset counter: 40
Mileage: 112344 km
Time Indication: 0
Date: 2020.09.28
Time: 01:49:45
02769 - Headlight Swivel Module; Left
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 27
Reset counter: 40
Mileage: 112344 km
Time Indication: 0
Date: 2020.09.28
Time: 02:14:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 40
Mileage: 112344 km
Time Indication: 0
Date: 2020.09.28
Time: 01:49:45
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 67
Reset counter: 40
Mileage: 114216 km
Time Indication: 0
Date: 2006.03.15
Time: 12:00:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Reset counter: 187
Mileage: 112568 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:06
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394G+067661758
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 56
Reset counter: 226
Mileage: 0 km
Time Indication: 0
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000069451
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2607012931
Coding: 344630393135313035442056413032363037303132393331
Shop #: WSC 00000 384 00290
5 Faults Found:
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 114223 km
Time Indication: 0
Date: 2021.01.17
Time: 08:10:51
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 17
Reset counter: 187
Mileage: 112566 km
Time Indication: 0
Date: 2020.12.18
Time: 17:32:06
02252 - Generator
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 10
Reset counter: 226
Mileage: 109319 km
Time Indication: 0
Date: 2019.04.26
Time: 17:12:26
02252 - Generator
Freeze Frame:
Fault Status: 00110011
Fault Priority: 1
Fault Frequency: 10
Reset counter: 226
Mileage: 109319 km
Time Indication: 0
Date: 2019.04.26
Time: 17:12:26
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 227
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.18
Time: 03:30:34
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900025689
Coding: 0062725
2 Faults Found:
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 114365 km
Time Indication: 0
Date: 2006.03.16
Time: 04:15:43
Freeze Frame:
(no units): 0.0
Voltage: 11.70 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 253
Reset counter: 216
Mileage: 111155 km
Time Indication: 0
Date: 2019.07.23
Time: 06:48:38
Freeze Frame:
(no units): 36.0
Temperature: 21.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606230018
Shop #: WSC 12336 024 394758
VCID: 343115B02232461B5BB-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12— Serial number: 525PA8-J6620TQ
Coding: 1000204
VCID: 5DE79014F138A753C45-8008
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 114222 km
Time Indication: 0
Date: 2006.03.15
Time: 12:08:46
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220619205014
Coding: 0021306
Shop #: WSC 131071 1023 2097151
VCID: 270BF2FCE3E43D83EE9-8072
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 79
Reset counter: 186
Mileage: 107236 km
Time Indication: 0
Date: 2019.02.11
Time: 16:29:12
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005086687
Coding: 0000000
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 222
Mileage: 98432 km
Time Indication: 0
Date: 2006.03.15
Time: 12:18:58
End----(Elapsed Time: 02:12, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
The car yesterday started with no engine light and ran perfectly smooth for an hour of me driving until I cut it off then back on later the car started acting up and shaking
I’ts important to clear all of the codes. Then check for codes when the car is acting up.
At this point you should see several codes not active if the car ran well. You kinda want to check then clear codes and then check again.
I would start with leaving the key to acc and clearing the codes. Then going back and seeing what codes come right back. List those codes.
Yeah I saw less codes yesterday I believe I saved it I’ll try to send those when I get to my computer but now it’s acting up
Sunday,13,June,2021,20:30:27:37531
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
VIN: WAUGN74F57N029270 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 36 37 42 46 47
4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN74F57N029270 Mileage: 114410km-71091miles
01-Engine – Status: Malfunction 1010
11-Engine II – Status: Malfunction 1010
31-Engine other – Status: Malfunction 1010
15-Airbags – Status: OK 0000
56-Radio – Status: OK 0000
1 Fault Found:
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114417 km
Time Indication: 0
Freeze Frame:
RPM: 173 /min
Load: 49.8 %
Speed: 0.0 km/h
Temperature: 107.0°C
Temperature: 72.0°C
Voltage: 10.033 V
Coding: 0000002
Coding: 0020920
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 230
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:58:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x42A2
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x00FF
18265 - Load Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:21:05
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x6282
Hex Value: 0x0028
Hex Value: 0x0196
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 233
Mileage: 114414 km
Time Indication: 0
Date: 2006.03.16
Time: 10:04:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x6206
Hex Value: 0x0013
Hex Value: 0x859D
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 114414 km
Time Indication: 0
Date: 2006.03.16
Time: 10:04:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x6006
Hex Value: 0x002B
Hex Value: 0x059D
Hex Value: 0x00FF
Coding: 0000007
Coding: 0010003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:03:01
Coding: 0524330
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 234
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:39:10
Freeze Frame:
Temperature: 34.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:24:08
Freeze Frame:
Temperature: 106.0°C
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:25:19
Coding: 0115121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
4 Faults Found:
02747 - Solenoid for Bi-Xenon Shutter; Right
Freeze Frame:
Fault Status: 00111011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 230
Mileage: 114388 km
Time Indication: 0
Date: 2006.03.15
Time: 15:22:00
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 114368 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:00
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 114368 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 114368 km
Time Indication: 0
Date: 2006.03.15
Time: 12:52:00
Revision: 00000000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 189
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:39:06
Cannot be reached
Coding: 0014151
Coding: 0012141
Coding: 2129263
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 232
Mileage: 114389 km
Time Indication: 0
Date: 2006.03.15
Time: 15:25:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:20:50
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:20:49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:20:49
Coding: 0082954
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Revision: 00-00000
Coding: 0051947
Coding: 4618269
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 194
Mileage: 85830 km
Time Indication: 0
Date: 2016.01.19
Time: 07:52:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:22:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 96
Mileage: 112353 km
Time Indication: 0
Date: 2006.03.16
Time: 14:25:06
Coding: 0000026
Coding: 0012014
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 233
Mileage: 114408 km
Time Indication: 0
Date: 2006.03.16
Time: 09:20:00
Freeze Frame:
Voltage: 10.800 V
Temperature: 53.0°C
Revision: 00-00000
Coding: 0051947
Revision: --H04—
Coding: 0008022
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 22
Reset counter: 233
Mileage: 114408 km
Time Indication: 0
Date: 2006.03.16
Time: 09:20:49
Freeze Frame:
Voltage: 9.94 V
Count: 241
Coding: 0000016
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Mileage: 114376 km
Time Indication: 0
Date: 2006.03.15
Time: 14:39:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 233
Mileage: 114408 km
Time Indication: 0
Date: 2006.03.16
Time: 09:20:49
Coding: 0000002
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 13:19:17
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 13:22:42
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 13:22:53
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 13:23:02
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 233
Mileage: 114410 km
Time Indication: 0
Date: 2006.03.16
Time: 09:22:40
Coding: 0051754
Coding: 0062725
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 216
Mileage: 111155 km
Time Indication: 0
Date: 2019.07.23
Time: 06:48:38
Freeze Frame:
(no units): 36.0
Temperature: 21.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1000204
Coding: 0051754
Coding: 0021306
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 190
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:21:51
Coding: 0000000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 189
Mileage: 114371 km
Time Indication: 0
Date: 2006.03.15
Time: 14:39:11
End----------(Elapsed Time: 02:19, VBatt start/end: 13.8V/14.0V)-----------
I also forgot to mention I opened the computer up and one of the power pins on the computer power was jumping erratically from 4,7,8 to 12,13 volts
Anything under 12 and that’s when everything with all these codes are showing. This car been doing it before I messed with engine and back all the way from last year it seems to have gradually got worse.
So I tested the pin on the computer when the car cuts off and the computer completely looses all its power when it happens and I did test the positive by it and it’s a constant 12.48 volts
I’m thinking of soldering a wire and running it directly to the power to see if it starts working
You just have an never ending list of com error codes. So something obviously is off there.
The thought leans to a wire harness issue as you said sometimes it good and then other times it’s not.
Start with the full sweep of the fuses and work your way into the wire harness.
Hey Justin so today I pulled the cover off under the steering wheel to take a look at the fuses and relays and I saw that one of red harness pieces I unhooked had water in it and was corroded so I blew it out and put it on and majority of that codes are gone I will send them when I get a chance I’m still getting open circuit for some things but the car hasn’t cut off on me
Monday,14,June,2021,18:22:52:37531
VIN: WAUGN74F57N029270 Mileage: 114440km-71109miles
07-Control Head – Status: OK 0000
61-Battery Regul. – Status: OK 0000
4 Faults Found:
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:28
Freeze Frame:
RPM: 617 /min
Load: 21.2 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 36.0°C
Voltage: 13.716 V
P1653 - 001 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:40:07
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 104.0°C
Temperature: 55.0°C
Voltage: 0.381 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:40:07
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Voltage: 0.127 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114437 km
Time Indication: 0
Freeze Frame:
RPM: 986 /min
Load: 53.7 %
Speed: 0.0 km/h
Temperature: 58.0°C
Voltage: 11.303 V
Readiness: 0010 1101
Coding: 0000002
Coding: 0020920
Coding: 0000007
Coding: 0010003
Coding: 0524330
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 114420 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:30
Freeze Frame:
Temperature: 51.0°C
Coding: 0115121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 114420 km
Time Indication: 0
Date: 2006.03.15
Time: 14:05:00
Revision: 00000000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 196
Mileage: 114420 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:26
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:03:28
Freeze Frame:
RPM: 620 /min
Load: 21.2 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 36.0°C
Voltage: 13.716 V
P3247 - 004 - Open - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:10:43
Freeze Frame:
RPM: 668 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 37.0°C
Voltage: 13.970 V
U0235 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:40:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Voltage: 0.635 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:40:07
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Voltage: 0.381 V
P3217 - 004 - Open - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 114415 km
Time Indication: 0
Date: 2006.03.15
Time: 12:43:49
Freeze Frame:
RPM: 1856 /min
Load: 18.0 %
Speed: 63.0 km/h
Temperature: 54.0°C
Voltage: 13.970 V
000036 - Bank 2: Camshaft B (Exhaust)
P0024 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 114417 km
Time Indication: 0
Date: 2006.03.15
Time: 12:46:41
Freeze Frame:
RPM: 599 /min
Load: 34.1 %
Speed: 2.0 km/h
Temperature: 110.0°C
Temperature: 51.0°C
Voltage: 13.843 V
Coding: 0014151
Coding: 0012141
Coding: 2129263
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 236
Mileage: 114421 km
Time Indication: 0
Date: 2006.03.15
Time: 14:07:52
Coding: 0082954
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 114420 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:25
Revision: 00-00000
Coding: 0051947
Coding: 4618269
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 196
Mileage: 85830 km
Time Indication: 0
Date: 2016.01.19
Time: 07:52:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 28
Reset counter: 96
Mileage: 112353 km
Time Indication: 0
Date: 2006.03.16
Time: 14:25:06
Coding: 0000026
Coding: 0012014
Revision: 00-00000
Coding: 0051947
Revision: --H04—
Coding: 0008022
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 114424 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:27
Coding: 0000002
Coding: 0051754
Coding: 0062725
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 216
Mileage: 111155 km
Time Indication: 0
Date: 2019.07.23
Time: 06:48:38
Freeze Frame:
(no units): 36.0
Temperature: 21.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1000204
Coding: 0051754
Coding: 0021306
1 Fault Found:
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 114420 km
Time Indication: 0
Date: 2006.03.15
Time: 14:04:27
Coding: 0000000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 196
Mileage: 114420 km
Time Indication: 0
Date: 2006.03.15
Time: 14:02:31
End----------(Elapsed Time: 02:04, VBatt start/end: 13.6V/14.1V)-----------
Well that would make good sense that with all of those codes you’d have water or some sort of interference going on.
I would take the next step to check all of the fuse boxes and relays in the car. Then start going into the modules themselves. Like starting with the ABS module that has the codes and seeing if you can run an output test and then working backwords from there.
Does anyone have the pin diagram to the engine computer
