I guess now I will buy a new y pipe for both sides since the flex pipe is broken
My question during my downtime for this can I put the entire engine in and put this in after or will it be to much trouble?
Looks like people have welded in new flex pipes. Thatās what I plan on doing for my engine drop.
I reviewed the manual last night. For one side it says the Y pipe must be removed with the engine out. For the other side it says you can remove it with the engine in. In my post asking about flex pipes it looks like there may have been someone who got them out and back in with the engine in.
Yeah I guess itās a mixed thing I assume itās when the bolts are completely rusted and arenāt a bolt anymore so they canāt come off and I guess when they are still intact they can be removed when engine is still in the car
Definitely weld in new flex. A much more cost effective solution. Thatās what I did.
Ed
I just bought new pipes for $540 a piece I didnāt want to be bothered with finding someone to weld it and pipe look like it was rusting all the way through
Hey guys so I randomly thought of putting a o ring into this piece where it rattles and it actually stopped it from moving around which causes the rattle but my question is can a o ring survive in there? I do have the spacers and if they canāt survive Iām going to make a screw from outside that goes in to hold that into place. So screw will have threads where it will hold it in and on part where itās holding the flaps Iāll make it round.
Performance Tool W5239 Polymer Viton O-Ring Assortment, Brown, 180 Pieces, 9mm-20mm https://www.amazon.com/dp/B01N8ZLHQO/ref=cm_sw_r_cp_api_glt_fabc_6AYXTF3YYY8C3AC7KQWV
Iām thinking this if I go with the gasket route
Looks great. while you have it open just double check each mount and if needed add a small amount of epoxy.
I did and expoy 2 of pieces back it probably was loose from manifold rattling freely and I have manifold back together and on the engine now Iām hooking up the final hoses before I put engine back in
Can the engine mounts be changed when the engine is in the car?
I have done it myself, but I needed the 3/8ā ratchet wrench that had 2 articulating joints to get to the top nut on the mount, especially for the driver side which is super hard.
I used one of the engine bay support bar that fits on either side of the engine bay.
Having triple squares helps a lot.
So pretty much Iāll have to drop the subframe and use the tool you listed
Or you just leave the subframe and still take it off?
I had to take the sway bar off, and one crossmember if I recall. It wasnāt very involved, just very tight
Ok I gotcha and on the other note I been up since yesterday putting engine in I have it all lined up I just have to jack it up and screw it all in and since Iām in NY and itās raining like hell I made a tent over the car so I should have engine in today or early tomorrow morning. I have a tight deadline with finishing this car. Iām going to use the broken engine mount for now to get it driving and when I buy this lift next week from my friend Iāll change it. Engine mount is leaking fluid out but should hopefully make it another week or two lol
Does anyone know where this heat shield goes? Iām assuming it goes over the transmission shifter cable
Thatās definitely for the shifter I figured that out. How do you install the shifter cable to transmission itās giving me a hard time
