Figured out the shifter and I have subframe back on the car.
Does anyone know what goes here?
Hello everyone so I have started the car and for some reason the car keeps shaking. No engine light on at all but the engine mount is busted but I was forced to put it on because of my deadline. Is it the engine mount causing the car to shake?
I’ve had shake from a cracked throttle body mount. It threw a code lean bank though.
I’ve also done engine mounts and the results are worth it, passenger was bad and shook a bit.
Ok thanks and when I rev it over 2000 rpm it’s smoother
The shaking can’t be from the timing right? If it was shouldn’t I have engine light on? I have no engine codes at all. The car isn’t misfiring and is only shaking. When I do over 2000 rpm the car is smooth
Also the epc light is on
Does that mean I screwed up the cams?
Is it safe for me keep driving car how it is with this?
Clear the codes With the car at idle. See if the codes come right back… If they do then. Leave the key to acc but not started. Clear the codes and. See if the code comes back right away.
I did they came back
Hey Count could I just leave it how it is? It won’t hurt the car right
The car Idles and Revs fine it just has a little shake though probably the engine mount
Funny thing is father like son he did the same thing on his old Audi he accidentally advanced the timing
I replyed back to the pm.
Shake can def be from the motor mount as well espically if it’s in bad shape. On the codes. See if you can type them in long hand there is a bit of a glare anytime I look at them. made it hard to read.
Can adjustment codes can pop up right after you do a lot of work on the motor and have the motor down for a long time as the actuators need to pump up with oil pressure and some can take a bit longer than others.
Alright thanks and my bad I’ll type it or send better pictures
Hey Justin with the Ross tech can I change the ecu with a used one and code it to the car?
Does anyone have a pin diagram to the ecu. I’m getting all these lost communication codes and under voltage to the o2 sensors and everything to the car and by the way ever since I got the car back from last year it had these under voltage codes and gradually got worse the ecu 1 has wires bypassing the pins that were dead. I did do a Ross tech scan but is too big to upload into the chat
