PART 4
Cam Chain Tensioner Cylinders 1-4 (Part Number 079109210L) & Cam Chain Tensioner Cylinders 5-8 (Part Number 079109204L) - These items (Both Different) have two functions, one is to keep tension on the timing chain in between the inlet & exhaust sprockets and the second function is to receive electronic signals from the ECU to adjust the variable timing.
The Tensioner part of the unit is static, more like a chain guide and does not move to take up any slack in the chain, just keeps it taught and in the right position.
The more important function of the unit is to receive a signal from the ECU, which then activates the actuator/solenoid… the part of the unit I showed at the end of PART 3. When the electronic signal is received, it moves a piston within the actuator/solenoid, which then block or opens the holes you see in the actuator. This allow oil, under pressure to be sent via the oil galleries to the Mechanical Adjusters, described in PART 3. The oil under pressure then releases the locking pin, allowing the mechanical adjusters to vary the cam timing - Hence Variable timing on the inlet cams, allowing the timing to be set correctly at all times, dependant on the load (Accelerating Hard, Cruising Gently, Or off the throttle.
See the complete unit below :
http://i18.photobucket.com/albums/b118/jimgreen72/107ef8a0-05a7-4dcf-a96d-dc30aaa2565d_zpsb538593b.jpg
Alongside the complete unit (Including the Actuator/Solenoid), you will see a solenoid that I removed from one of my new units to test.
Here is a close up of the Actuator/Solenoid so you can see the holes where the oil flows from when a signal from the ECU moves the piston which is inside the cylinder of the Actuator.
http://i18.photobucket.com/albums/b118/jimgreen72/IMG_21161_zps4aff9658.jpg
You can make out from the picture above, that in this picture, the piston in the actuator is in the closed position, the holes are closed by the piston, which would prevent flow to the mechanical adjusters, leaving the locking pin in the close position.
The picture below, shows one of my old actuators with the piston in the open position (You can see that the holes are open) this would be in the position to allow oil to the mechanical adjusters, releasing the locking pin and adjusting the variable timing.
http://i18.photobucket.com/albums/b118/jimgreen72/IMG_21081_zps2ab1c3f0.jpg
The wear on the tensioner part of the unit was minimal (approx. 10thou of an inch) all it appear to have done was wear a shiny line where the chain had been passing over the plastic.
These were probably the least worn part of any of the components that I changed.
The part numbers on my old items differed slightly from the new items which now have the letter “L” after the part number and I have been reliably informed that these units have been updated on more than one occasion.
Below is a picture of one of my old units, showing the original part number :
http://i18.photobucket.com/albums/b118/jimgreen72/d33eb36f-c3a1-477d-974f-1b5404b4d834_zpsb6c2aaba.jpg
Now to complete the story of my rebuild for those who haven’t been following it.
I fitted the two new units to my engine along with all of the other new parts. When we fired up the engine it ran perfectly for about the first five or six miles, then started running slightly rough with a distinct lack of acceleration.
Having got the car back to the workshop and hooked it up to VAGCOM, it showed two fault codes, both indicating that the variable timing was not retarding. We were confident that we had set the timing correct and had the mechanical adjusters set correctly in the locked position. After many posts and advice from quite a few of the experts, it pointed to either the mechanical adjusters, or the electronic adjusters which we are talking about in this section.
We managed to remove all of these items (2 X Mechanical Adjusters & both Electronic Adjusters) without removing the engine, but on reflection, it may well have been quicker and easier to go that route and just remove the engine again. It is possible to remove these items with the engine in Situ, but it is very tight work.
Having removed all of these parts and dismantled the mechanical adjusters, we found they were operating correctly with no issued and we also confirmed that both the timing and the mechanical adjusters had been set up correctly with the pins in the locked position, this suggested that for some reason they were not adjusting the variable timing.
Moving backwards, we now ended up at the electrical adjusters, the actuators/solenoid being responsible for sending oil to the Mechanical Adjusters to vary the timing. We decided to remove the actuators and test them to ensure the pistons were moving correctly. The test is very easy as there are two terminals on each actuator. Simply put 12volts pos on one of the terminals and negative to the other, the piston should move in one direction… swap the polarity and the piston should move in the other direction… DID THIS HAPPEN, NO. On one actuator the piston appeared to be stuck, but you could feel the unit trembling as though it was trying to move the piston.
We then checked the second unit, the piston moved in one direction, but failed to return again.
BOTH OF THESE UNITS WERE DEFECTIVE (Both genuine Audi and Purchased From Audi).
They were taken back and we were supplied with another two units.
We tested both of the actuators prior to fitting them back in the engine and they worked correctly. After many hours of additional work, the engine was started again and we took the car for a drive and it performed faultlessly… for about 12 miles when the problem returned.
We had a small VAGCOM hand unit with us and we pulled over and downloaded the fault codes… sure enough, same codes, same problem.
At this point I started a VERY disappointing drive back home, not really knowing what to do. I deliberately was driving on and off the throttle… Suddenly the car burst back into life again and drove perfectly all the way back home. On arrival I cleared the codes and have been driving it ever since with no further problems.
I believe that the clearances between the piston and cylinder of the Actuator Unit’s are two tight, causing the piston to stick, particularly when they are new and have first been fitted, this is the only explanation I can think off as they come fully lubricated.
We have informed our dealer of our suspicions, but we have not received any feedback. My workshop are at the moment in talks with the supplier in an attempt to obtain some good will gesture, due to the huge additional work that was required to basically remove half of the engine again, due to receiving defective parts. Take into account that these two units are close to £900 pound sterling for the two.
If you have the same problem when fitting these units with the letter “L” after the part number, these are the revised units and if we have others with the same issues, this would prove a point. If this does happen to anyone, before you pull the engine again, go for a long drive in the hope that they will after some movement, start operating correctly.
I’m still driving with my fingers crossed.
PART 5 To Follow Shortly
