Funny you should ask… just came on here to post an update…
So a few things
Went on an audi cruise this weekend, so the car was getting used hard.
Had a fresh tank for Sat with the new button… everything was working… bottle heated up, purge button and solenoid were working… next issue arises!
The system seems to be firing when armed and past 4k RPM, but regardless of WOT.
So i found myself have to disarm the system until right before i was ready to use it.
Any thoughts on this? Is there a way to reset the nitrous controller?
Regardless, i ended up going through a full bottle on Saturday… made some great pulls… when its on it on hard. Makes a huge difference!
Next issue…
Sunday morning i opened the bottle and heard a leaking sound… narrowed it down to the nitrous filter.
Just spend the last hour messing around with various connections going into it and making sure everything was tight… and the conclusion is that there is a leak in the actual housing of the filter… end of the housing on the OUT side… right at the seam of the cylinder.
So, yes, this is the second part from this kit to fail within the first 3 tanks for N20…
I want to order a replacement filter and want to verify the size of the fittings.
4AN - http://www.nitrousexpress.com/15607-d-4-pure-flo-n20-filter-7-stainless-hose-lifetime-cleanable.html
or 6AN - http://www.nitrousexpress.com/15610-d-6-pure-flo-n20-filter-7-stainless-hose-lifetime-cleanable.html
Thanks once again… we’ll get there!
