Spent a good amount of time working on the engine today. So close to having it wrapped up, maybe in time for winter haha
Auto tensioner and alternator are on. I had to remove the coolant pipe when I resealed the oil pan. I had issues getting the pipe off the water pump so I ended up removing the water pump as well. I gotta order a couple new o rings before I put the water pump back in
http://i68.tinypic.com/sql1zq.jpg
Intake manifold, fuel rail, injectors, anything related to that stuff is all on the engine and ready to go
http://i64.tinypic.com/24njksx.jpg
Made up new oil lines for the oil cooler setup. Love me some aeroquip hose and fittings
http://i68.tinypic.com/29gii2q.jpg
http://i68.tinypic.com/v3jc5s.jpg
I decided to change the oil thermostat. Went with the Earl’s one because it has 3 ports for pressure/temperature sensors. I plan on running dual oil temp sensors. Oil coming out, oil coming in
Comparison picture
http://i68.tinypic.com/2e3zbx1.jpg
Flywheel is on and torqued. Along with everything else in the backside.
http://i64.tinypic.com/okvos4.jpg
I can’t find my clutch alignment tool so once I do, I can finish the clutch assembly.
I am not really that far from having this engine completely back together.
Still to do on the engine:
-Finish valve covers
-Put water pump back on with new o rings
-Install headers
-Install coolant pipes
Once I get those items finished, I still have a few things to do getting it back in. I need to weld bungs in my downpipes for my air fuel sensors, make a bracket to hold oil cooler and ps cooler, make new ps hoses for cooler setup, put in gauges for air fuel and oil temps, put 4:1 diff in before putting trans on engine, and then button everything up
Next few weeks are busy with the SCCA national championships in less than a week and we are in full swing getting prepped.
Fingers crossed I finish before winter haha
