I was talking to the person I was quoting, not you. Apparently it could be interpreted in two different ways.
Anyway, to put the rest of the pissing contest on hold for a minute, since I got back earlier this week I’ve done quite a few runs and I’ve concluded the car is running fine. Most of the performance deficit has disappeared after I removed the extra battery from the car and inflated the tires to a normal pressure. The guy who put them on had set them to 27-28 psi :
Good thing I didn’t hit any major potholes yet.
Temperature increases explain the rest of the performance delta. I did a few tests between 18 and 25C and for ever 3 degrees C increase in that bracket the car went 0.1s slower in the 3rd gear test. In the end it did an 8.00 at 21 degrees C which means it should end up back at 7.6-7.7 when winter returns. Assuming roughly 0.1s gained from the JHM tune. Still looking at the exhaust, only thing is that I kind of like how it sounds now. Worried that even a resonated JHM will drown out most of the delicious intake sound.
I want to run a hose from the front bumper to the airbox flap intake to bring down intake temps. So much appears to be lost from sucking in warm-ish air at that point. Given the climate here I’ll just ditch the aux rad on that side and run a 90mm hose through the gap. Should be pretty noticeable. I managed to do a few runs back to back and the second run was always considerably quicker with intake temps 3-4C lower. Not an issue if you’ve been cruising on a highway for the past half hour, but with the driving I get here it’s not ideal.
Unfortunately I’ve had to cancel the road trip in the RS4 after some objections from my other half and a time/effort issue to get the car back to Moscow afterwards. Instead I’ve dropped the car off at a place nearby which will - at last - do the gearbox rebuild. Just had to go with my gut feeling selecting a shop, no useful info or recommendations to be found. So fingers crossed.
I’ll try to drive it to Norway year when the car won’t have to come all the way back. Instead I’ll pick up a 991 in Hamburg and make the trip from there. Should be a good drive, about 2000 miles in a week. The RS4 would’ve been more fun but at least I’ll get a better idea of what it’s like living with a 911. I’m guessing I may have an issue getting my fishing poles into it.
It won’t look as good, that’s for sure. Love the passive aggressive look of the B7.
http://www.greenringer.net/various/IMG_1436s.jpg
