Small update,
Decided to not install the supplied solid plastic cover behind the fog light grill, instead found some black anodized aluminum mesh and installed that, prefer the look and should keep large debris out.
Fog Light Mesh
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/Fog%20Grill%20Mesh_zpsutyxhnyl.jpg
Noticed a small drop of oil on the floor after some spirit driving this past Saturday, position was just behind the front bumper on the driver side. Immediately suspect the new oil cooler lines that was installed and more specifically the multi joint connector on the JHM lines. Pulled the fog light grill and could see a small amount of oil directly below the connector so I might have to tighten the nut on the line and not the nut connecting to the oil cooler. Nothing serious though, will keep an eye on it and tighten that up when I remove the bumper over December ofr some other things I have planned.
Connector Leak
http://i1175.photobucket.com/albums/r630/rudivn/JHM%20Stage%201/Oil%20Line%20Leak_zps3ojyqzmg.jpg
Other than that, nothing else to complain about.
