Take the RS6’s out of my above post if you disagree with that part of it then.  The point of my above post was that the logic of the post that I quoted is retarded as it pertains to Tial 605’s; not really trying to make a point about the RS6’s (though I will address that below).  Cars have gears for a reason, and turbos the size of Tial 605’s do indeed spool in plenty of time on the 2.7l in 1st and 2nd gear to enjoy them without having to always be breaking the law.
You and whomever can complain about EPL/AMD peak dyno numbers all you want, but are you really trying to say that AMD and EPL’s MAP boost sensors are terribly off and optimistic?  If that’s not what you’re saying, then I’m not sure why you would try to discount an EPL vs EPL comparison as far as spool is concerned between the two turbo setups, considering that comparing the same tuner etc, with only the turbos changed takes out the most variables possible for an accurate comparison.  It’s not like EPL was sandbagging the RS6’s when they tuned them a couple of years ago (before the Tial 605’s were even a reality) so that RS6’s can look comparable to 605’s.  I think it’s safe to assume that they tried their best on both setups, and that it is indeed realistic to compare real customer setups from the same company.
BTW, I’m not an EPL nutswinger, nor a Tial nutswinger, as I neither own nor necessarily plan to own anything from either company (well, I guess I’ve got tial wastegates ha).  And my comparisons of the RS6’s are by no means only coming from EPL. I’ve been on the various Audi forums for years, and have been looking at the powerband/boost profiles/dynos/logs of RS6 cars from many tuners (VAST, ASP, EPL, etc), and analyzed all that I came across, not just EPL, pretty heavily before I decided to buy my set of RS6’s back like 4 years ago.  For example, here’s some ASP dyno graphs with boost data, not from EPL, that I saved from back in the day and re-posted in this thread on Audizine:
http://www.audizine.com/forum/showthread.php/277341-Official-RS6-turbo-S4-car-consolidation-thread?p=3639387&viewfull=1#post3639387
[QUOTE=jibberjive;3639387][QUOTE=Don Supreme;3620147]Post some rs6 dyno charts in this thread.
Here’s some that I’ve found
This car is stock engine other than rods, ASP’s exhaust mani’s, DP’s, and FMIC
[QUOTE=lil’ is 300;2356442]Here are ASP’s results they posted…
451whp, 472wtq on 93 octane at 28.5 psi
http://www.autospeed.us/pics/RS6_93.jpg
502whp, 475wtq on VP109 at 28 psi
http://www.autospeed.us/pics/RS6_VP109.jpg
The second chart here is the same one posted above
[QUOTE=lil’ is 300;2370180]ASP just tuned another RS6 car. The difference between the last car and this one is this car has: Port and polish S4 heads to match RS4 intake ports, RS4 intake manifold, RS4 throttle body…all the RS4 inake stuff, RS4 intake cams, Rosten rods and ASP exhaust manifolds… full list here
93 octane - 465whp, 492wtq at 28psi. Full boost at 4100 rpm. The last RS6 car was making full boost at 4500 rpm (maybe all the RS4 stuff and headers made spool sooner?)
http://www.autospeed.us/pics/RS6-93Octane.jpg
Here is the other RS6 car posted before without RS4 parts and stock manifolds
93 octane - 451whp, 472wtq
I overlaid the two graphs so see the diff…If you compare the two graphs before peak torque and power is hit, the RS4 parts car is making a lot more torque and hp below the curve.
http://img176.imageshack.us/img176/6887/picture1nt0.png
And here’s a race gas dyno chart of the 2nd car with the RS4 intake stuff
http://www.audizine.com/gallery/data/500/RS6-109.jpg
Keep in mind these are just 2 RS6 setups from one tuner, and from one dyno.  A different tuner, dyno, and conditions could vary these numbers and curve drastically, up, down, or side-to-side.
I’m sure there’s more RS6 turbo dyno charts out there, so feel free to post them if you have any!
From the data I’ve seen over the years, the RS6’s tend to spool ~15psi around 3500-3800RPM, which is very similar to what most Tial 605 setups spool like, and coincidentally similar to what my GT turbos spool like (15psi is the data point that I’ve been paying the most attention to as that is where my setup is currently limited to, and I wanted to compare my spool to the different setups. My turbos are a good bit smaller than GT28rs’, just in case you’re not familiar with my setup.)  My conclusions are drawn from data over the years, not just a single EPL glory chart, and I am basing spool comparing psi to psi, not necessarily power.  I wouldn’t be surprised if RS6’s felt a little snappier slightly down lower in the 3k RPM range than 605’s, but to say or imply that an average 605 setup spools like an average GT2871 setup is blatantly misleading.
I do, however, definitely defer to peoples’ real-world experience (like you apparently have and PureEvil with his personal setups, though his objectivity isn’t necessarily proven as it seems he has a bone to pick with Tial’s customer service), so I take what you guys say at face value and believe that the RS6 setup(s) you drove felt snappier than the 605 setup(s) you drove. And that wouldn’t surprise me much, as the vast majority of the objective data shows that they are relatively comparable turbos, with the RS6’s likely having a slight edge in spool and 605’s likely having the slight edge in the top end.
[quote=“PureEvil,post:48,topic:3572”]
Good data point to have.  It seems like you may not have ever had a properly functioning set of turbos though, so I’m not sure if your comparison should be indicative of how a properly functioning set of turbos would be.  I’m looking forward to you fleshing out the details of your original post though, as, like I often say, the more data the better for people considering different turbo setups.
Since I sold my last set of RS6’s I have had thoughts about snagging a cheap used set of RS6 turbos, modifying them myself for the 2.7t, and putting them on an allroad to daily drive.  It is still a high possibility, as I really like their powerband for the stock motor and they seem like they daily-drive well.
EDIT: Just for full disclosure, I started typing my response before CallingUout edited his post, and when I was writing this post, the last sentence of his post said something ridiculous like “Plain pump gas only RS6 cars commonly make 13lbs before 3000 rpm & 20+lbs by 3700 rpms, the difference between the 2 is more like 1000+ rpms.”  Though everything I said in this post still stands, I just wanted to clarify that he changed some of those figures to be slightly more realistic.
