Piggy back goes oink oink...
Lots of butt dyno’s! Lol. One guy even said his supercharger wine is louder with it. Lol.
Look at post #405. Doesn’t the “us” word seem a little weird.
Plus if this is just some guy that bought this and wanted to post his results just so people would know they have a cheaper choice. Then why is is so worried about helping everyone that has a problem and making sure everyone is happy with it.
Any chance he is tied in to Audizine somehow? I got a message from a Audizine moderator that knew a awful lot about this guy. Then in a post the op said he knew the guy that started Audizine.
check this out…i havnt posted it on AZ yet
http://mbworld.org/forums/c-class-w204/436373-review-jb-beta-tune-c250.html
the same guy…
I’m not even going to post that there. Let the idiots be idiots…
yeah? I really don’t think that’s the case, but who knows. beaver diver seems like he has something at stake
ask him that very direct question and see how he handles it. ‘Have you or will you b e n e f i t financially in any way from this product?’
My big question is how the thread hasn’t been shut down by moderators. It’s an unauthorized group buy from a non-vendor. They used to go nuts about that shit.
APR is the section sponsor, and the company that stands to lose the most money. Wonder if they’re not paying Audizine or something because they seem to not be getting the support they should expect as an advertiser.
Responses I got from a audizine moderator.
As for bhvrdr, he has been on here for more than 10 years. He is not European90 and from what I can tell, the two are not connected any more than he is a past customer who came in here to say something good.
It is not obvious that bhvrdr is selling anything. I can look at IP addresses for the users and see they are in two very different areas. yes, IP can be masked, but when you look at Chipwerke, they are in TURKEY. Long way from Florida where bhvrdr is from. Maybe he is their US Sales Rep…I doubt it.
The only possibility I see is he pinged the seller with “hey, will you guys give me a discount on the product, I’ll write a review on AZ if I’m happy with it”. But I doubt he is some kind of sales guy. Just really likes piggybacks.
As far as how this thing works, here’s your technical overview:
http://www.audizine.com/forum/showthread.php/645409-B8-5-S4-stock-versus-APR-Stage-1-tune-versus-Chipwerke-piggy-back?p=10659805&viewfull=1#post10659805
I’m not one to shit on someone who can’t speak/read english, cause it’s a big world out there, but that response doesn’t make sense grammatically nor technically. Can’t believe people are playing surgeon with their cars with this thing. Maybe at least the BMW guys have a pretty competent person running the show. This makes those rs4 turbo guys look like rhodes scholars.
I think he has admitted that the ‘pro’ version is 50$ for a dial settings change. And now the guy is recommending that you buy the ‘pro’ and a ECU tune and use them together. This is laughable
So I seem to remember some saying that the early REVO tunes set the boost request so something unachievable and there seemed to be general consensus that this was either 1) bad tuning, or 2) dangerous. Am I remembering that correctly.
Taking the info posted over on AZ - I was able to build a boost request curve and compare it to the APR published data for Stg 1.
This is what the box appears to do to the voltage coming from the map sensors if the curve they posted is accurate :
http://i616.photobucket.com/albums/tt241/jgreat_bucket/S5/map_sensor_alter_zps3btanwjz.png
And this is the resulting effective boost request :
http://i616.photobucket.com/albums/tt241/jgreat_bucket/S5/boost_alter_zpssd34vmk1.png
Seems if you really wanted to tailor a piggy-back box for the 3.0T you could do a lot better in shaping the voltage modification than this, right?
Interested to listen what the experts here think - I’ve got no experience or knowledge of this stuff.
Jim
Good stuff Jim, so your assumption is that the sensor is simply a static map between voltages?
But then wtf was the vendor talking about when he said “rev sens” (link http://www.audizine.com/forum/showthread.php/645409-B8-5-S4-stock-versus-APR-Stage-1-tune-versus-Chipwerke-piggy-back?p=10659805&viewfull=1#post10659805 ) ??? I’m kind of amazed they want this thing to work when you “punch the gas pedal”…BUT…there is no actual signal measured to indicate throttle position or RPMS :o. Even when 034/Arin@apr were discussing this piggyback (link http://www.audizine.com/forum/showthread.php/553533-ECU-upgrade-is-91-octane-safe-in-Race-mode-(100-octane)?p=8997549&viewfull=1#post8997549), they assumed RPM’s were grabbed from the cam sensors, which is FALSE. Seems like a sketchy proposition at best, couldn’t add a second harness to grab a signal from somewhere else…makes this thing look extremely budget focused.
Now back to Jim’s graph…
Here’s the technical question - if what 034/Arin say is correct, a PID controller is going to sit there and try and achieve the requested boost. Let’s assume for the sake of discussion that it’s a simple controller, possibly with a feed-forward element, and not something more exotic. If any of you have a basic undergrad course in control systems, you’ll know that this is pretty much integrator wind-up city. So now your boost control (bypass valve) is essentially a max transient response to RBF_AV = 0. How does that affect drivability? Well, IF the controller is gain scheduled on throttle pedal or there is sufficient anti-wind up in place, then maybe it’s OK if you feather the pedal back. But that is a big IF, because the engineers were not tuning the controller to deal with these types of set-points. My guess is they tuned their controller to achieve smooth transients, since all the fueling (feedfoward component)/timing/cam phasing will likely have smaller time scales, and will probably rely on smooth boost curves. Maybe the closed-loop elements of the above systems can save the day, but I would be kind of skeptical. I think the engine will run like crap under the right initial conditions, input sequence and environmental conditions. But the sensation of “boost surge” like described in the AZ thread seems very possible, so now your smooth supercharged engine response has some weird laggy turbo feel. Great.
We’ve seen from Revo logs that bypass is opened ever so slightly near redline or when shifting…this would likely not happen with the re-maped MAP signal. Just a thought, not sure Revo’s strategy is close to correct, but would be impossible to enact with this piggyback.
I never thought there was anything wrong with jamming the bleedoff closed (the effect of asking for infinity boost). I’m no calibrator though.
To be honest, REVO got destroyed for that…only to have APR and GIAC release ‘version 2’ which did something similar because their customers in some power producing climates were reporting boost bleedoff. Wasted power. Their version one tunes with pulleys saw them push the blower hard with RPMS, but then the bleedoff would waste the work. Didn’t make sense, and after getting their heads handed to them by REVO stage 1 cars, APR and GIAC followed REVO’s lead. I’m talking 2010-2011 here. Eventually the APR and GIAC cars would pass REVO over comfortably.
Where REVO was catching shit was in asking for very high levels of ignition timing. This too is not necessarily a bad thing to a certain extent but there’s a limit, and beyond it, it hurts performance, doesn’t help. Where they really caught shit was for de-sensitizing the car’s knock detection. This results in the car not being able to pull ignition timing and can result in serious engine trouble…and did for 3 people we know of.
Ironically now it appears REVO have changed their tuning parameters and now they’re struggling with boost bleedoff, resulting in their pullied cars falling on their face up top.
I’m not a calibrator either, but the question would be did APR/REVO/GIAC modify other parts of the ECM controls to align with the unattainable boost request? Or are they simply going for the minimal code manipulation to create the effect Jim shows above. I would wager they changed some other elements of the system. Support of that claim would be lack of “turbo boost” like sensation.
I guess an interesting question is to go see what exactly the requested boost looks like for a stg 2 car.
On a side note I bought a POS windows 8 tablet to log at the drag strip yesterday (didn’t run great, 12.5@110 type times)…well don’t buy $100 tablets from best buy. That POS didn’t work once I got there. Pretty pissed because I was planning to go through all of APR’s logging suggestions. Now I’ll have to do it on public roads.
To be honest, I have not read the entire 18 pages of info in that thread – most of it seems to be people bickering back and forth… so I may have missed something. But it sounded to me as if the only thing you plugged in was to the 2 MAP/IAT sensors. Did I miss something? I just took the posted volt-vs-volt and applied that to the MAP sensor response to create the curves I posted. From reading European90’s post that’s what it sounded like it does.
Even in that post about “rev sens” there is nothing that says anything about any kind of RPM sensor - it only talks about not kicking in until 1200mv which is about 6psi of vacuum - so still part throttle.
As for the driveability - keep in mind I only posted what it does at WOT - the MAP request the ECU should vary smoothly as you press the accelerator. You are in effect changing the gain down lower in the RPM range however, so it seems this would sort of act like a “sprint booster”. Wonder if that’s part of the “but dyno” response of this system - power would come on with less acc pedal travel, even if maximum power wasn’t changed (like at 2000 rpm where the charger is the limit, not the boost request).
I guess the reason for my curiosity was with the two knob “setting options” (such as ‘B’ ‘1’), which I believe correspond to magnitude and “when”. I suppose the “when” could just adjust the voltage at which the the sensor starts to “deviate”, and then magnitude determines by how much. Guess that makes sense. Not sure why I was assuming it was triggered on RPM, so I think you are correct, it is just a simple sensor map.
Regarding your second point - you are saying essentially that as you depress the throttle a slightly more, and the throttled pressure naturally enters the “manipulated” MAP value range, then you will have more pickup due to more boost? So in a sense, it is artificially changing the throttle plate mapping by forcing the bypass closed when the ECM wouldn’t necessarily do it. Seems like that would feel strange. Agree this could be part of the feeling of surge - since you aren’t always going full WOT to begin with, but rolling into it most of the time.
I could see that behavior becoming annoying if not desired. I wonder what the hysteresis will feel like right around that point of manipulation. Maybe the linear departure won’t make it too bad.
I wonder a little if these guys don’t equate time with money- sure they saved $500 (comparing the “pro” model cost to what I paid for the S1 portion of my package) but what are the hours of BS they’re going through to make it work properly worth (that’s if it will work properly)? And in the end the results will likely be less impressive S1… ???
Go get yourself one of those new Surface 3’s for 400 bucks. I’ve got a Surface 3 Pro myself (which rocks), but the regular 3 will do just fine.
I can’t wait for VCDS to be used on my phone.
I use a Dell Venue Pro that I picked up for around $250. Windows 8, and it came with office. It works fine for logging/VCDS.
My plan was to leave something in the car for dedicated vcds, but we’ll see, I’ll research it more. Thanks though, the ms tablet would definitely not underwhelm.
Well, the one full log that has been posted shows the car pulling over 10 degrees of timing at higher RPM’s. I thought the 5-6 I was seeing was bad. Something definitely is going on with that. There is no way the car is making much power with 7-11 degrees being pulled on multiple cylinders. Ouch… I will say everything else I saw in that one log looked fine, but I’d need to see more before drawing any final conclusions.
The last couple sets of logs I saw looked a lot better, but they are tweaking the settings, and running a pretty healthy mix of 91 and E85. I’d still like to see what this looks like on 91 and the standard settings most people are going to run. The one guy doing logging has yet to run strait 91 or the standard settings. The bypass valve is consistently staying closed, and timing looked good on the most recent set of logs 91/E85 logs (20 degrees, with little knock/timing pull).
There are still a lot of people reporting some form of drivability issues (usually shifting/hang-up/delay related). I think the gist of it is, if it works, it will add some power, but there are definitely going to be a good number of people with some form of drivability or quality issues (same as we have seen in the small sample). There is also the question of how the car is going to adapt to this over the long-term as that was an issue in the past.
I’ll still stand by what I said in my original post on AZ. It may be a viable option for some people that either understand what they are getting into, or get lucky that the out-of-box settings work with their car and fuel they are running. There are going to be another handful of people that have issues, and have no clue what they are doing and they’ll probably bail. People that want consistent headache free results are still going to be better served with a flash. I know I’m still more than happy I went that route based on what I have seen.
