Project Audi V10 5.2 performance. S6 / S8
After my last post, I left off where my OEM intake was in need of repair or replacement. Since the JHM intake fix wasn’t ready at the time I paid the money and got a new one.
As some of you might know Audi came up with a new intake design to address the issues with the early intake manifold issues.
The only problem was
http://audirevolution.net/addons/albums/images/645748978.jpg
My intake already was the new updated part number. Little good that did, the new updated intake manifolds clearly didn’t fix the issue. Again I found something odd. The build date on my intake manifold was well before my actual car was built.
As if that little find wasn’t great the next thing I found was equally just as bad.
http://audirevolution.net/addons/albums/images/545647093.jpg
As you can see this intake was made about 6 months before I bought it. It came directly from Audi but as you can see it’s not actually new. As you can see from the marks and grime on the intake, this intake manifold is a repaired intake manifold. Still same part number as my original one but clearly not new.
This to me is a little frustrating. Here is why. You don’t really know your intake is messed up unless you pull it apart and after you do that it takes a good amount of work to put it back together. Since there are no actual sensors on the intake flaps you don’t know if one or more are broken. So, at this point, everyone could have a broken intake and unless you pulled it off and checked you wouldn’t know. As if that’s not bad enough the fixed or repaired intakes from Audi don’t appear to have anything different so, there is a very good chance that this intake will suffer the same fate as my other intake.
I do plan on taking apart this intake at the end of every season to check and see if it’s still holding up. So, that will at least be helpful and I’ll see if there is anything different on the inside of the intake vs my original one. I would have to say I don’t think there is going to be anything different. If Audi changes something they change the part number to reflect it.
oh well. Sucks about the intake but It’s not like that is going to stop me. :slight_smile:
The next parts are the JHM intake spacers and the JHM crank pulley along with my SAI removal
Let’s start getting to the good parts. The performance parts.
One of the best single parts you can put on the V10 motors. Is the JHM intake spacers. We all know the V10 heat is such a big deal. That heat is the single cause for numerous issues from pre-aging gaskets and other parts to robbing power and the overall drawbacks of just having too much heat.
The JHM spacers are a simple but well-proven part. These have been around and used not just by JHM but by actual race teams to do the same task. The spacers have been used for years in the Audi market to help drastically reduce heat and help return performance.
http://audirevolution.net/addons/albums/images/372195110.jpg
If you’re talking about performance or just general ownership. The spacers really are a must when you pull the intake to do a carbon clean.
http://audirevolution.net/addons/albums/images/744921058.jpg
There are several things I like about the spacers. An additional thing I like on top of all the performance and other gains is that the JHM spacers actually work. They help seal the intake manifold from what I have seen. So, in my opinion, I see a better seal from the intake manifold to the heads as the JHM spacers make a nice fit and seal really well. This cuts down on the dreaded V10 misfire from intake leaks.
The only real note is to make sure to remove some of the motor pull assembly brackets when you install AND DO NOT REINSTALL THEM. If you try to reinstall the motor brackets you will get interference with the motor arm once the spacers are installed.
http://audirevolution.net/addons/albums/images/938121494.jpg
Below is a combination of Paul F and myself on how to do the following. Paul’s original thread can be found here
http://audirevolution.net/forum/index.php?topic=3221.0
First - here are the tools you will need:
1/4" drive ratcheting wrench
M8 Triple Square/12 Point
M10 Triple Square/12 Point
14mm Wrench/Spanner
17mm Wrench/Spanner
Needle Nose Pliers
Flat Screwdriver
Extendable magnet
Give yourself about 2 hours.
http://audirevolution.net/addons/albums/images/842997973.jpg
http://audirevolution.net/addons/albums/images/59604440.jpg
http://audirevolution.net/addons/albums/images/79215949.jpg
Quick Tip: If you pull these off when the motor is hot the intake will be a little softer and that helps the fittings come off a little bit easier.
Once off this is what it looks like.
http://audirevolution.net/addons/albums/images/354041629.jpg
http://audirevolution.net/addons/albums/images/294443031.jpg
http://audirevolution.net/addons/albums/images/880719920.jpg
Step 5 - Remove the valve/hose. Squeeze the clamp with the pliers and pull the hose up.
http://audirevolution.net/addons/albums/images/76174001.jpg
http://audirevolution.net/addons/albums/images/558325984.jpg
http://audirevolution.net/addons/albums/images/715313875.jpg
http://audirevolution.net/addons/albums/images/40925352.jpg
http://audirevolution.net/addons/albums/images/438001649.jpg
Now loosen the two lines on the left-hand side, at the pump only.
Step 9- Now move to the front of the intake manifold. Remove this little hose and move out of the way.
http://audirevolution.net/addons/albums/images/516554899.jpg
http://audirevolution.net/addons/albums/images/451343568.jpg
following codes:
http://audirevolution.net/addons/albums/images/853273554.jpg
http://audirevolution.net/addons/albums/images/987256986.jpg
http://audirevolution.net/addons/albums/images/892541809.jpg
As I mentioned above. The JHM intake spacers made a huge impact on lowering the overall underhood temps along with giving better cooler intake temps.
Some of the exciting things I’ve done are
The JHM intake spacers - check we talked about those a few posts above.
Carbon clean - talked about that - http://audirevolution.net/forum/index.php?topic=4000.0
Up-date plugs and coil packs. - Did that earlier in the thread.
Compression test - Did this earlier in the thread.
Cylinder inspection - Did this earlier in the thread
Intake manifold inspection - Did this earlier in the thread
Coming soon…
The JHM Lightweight crank pulley - almost 9lbs of weight savings.
The JHM Lightweight brake rotors front and back - weight savings you wouldn’t believe
JHM beta ECU and TCU tune.
Full custom 3" exhaust
SAI removal - coming soon with the crank pulley
Fuel filter - part of the oil change and fluid assessment.
Oil change and fluid assessment.
After all, that I show the tract tested results from all the above work.
Now back to the performance parts of the build. Last time we talked about the JHM intake spacers and their ability to help keep the 5.2 V10 heat issues in check. While the spacers are helpful at keeping the motor cooler and more efficient the motor could also beit from shedding some of that unnecessary weight strapped to the front end of the crankshaft.
http://audirevolution.net/addons/albums/images/125978846.jpg
You’re dropping almost 9lbs off the front of the crankshaft.
So, for those of you who don’t know where this is or what it looks like. Let me show you.
Here are all the important things I reference where they’re located and what they look like.
http://audirevolution.net/addons/albums/images/522405473.jpg
http://audirevolution.net/addons/albums/images/137177550.jpg
http://audirevolution.net/addons/albums/images/280039249.jpg
http://audirevolution.net/addons/albums/images/260811121.jpg
http://audirevolution.net/addons/albums/images/60208689.jpg
1800rpm
http://audirevolution.net/addons/albums/images/993579728.jpg
3200rpm
http://audirevolution.net/addons/albums/images/144367236.jpg
from 3200 back to idle.
http://audirevolution.net/addons/albums/images/393403474.jpg
GIVE ME A BRAKE… Next phase in the performance journey, was to replace my squeaking worn out brakes.
There are several options when it comes to just replacing the OEM rotors. For me, I’ve seen lots of guys go the cheap option and you get what you pay for. Cheap rotors tend to use cheap material that wears out quicker and doesn’t seem to offset the cost in the long run.
For me, I really want to bring out the supercar in my super car. So, the search for performance rotors started and as usual as most of you know there was nothing. So, I called the guys at JHM and asked what they could do. They have performance rotors for just about every other platform why not us. The S8 and S6 front rotors are the same on our cars so its like one big market.
I wanted a lighter more performance oriented rotor that would help drop some rotational weight while pulling out the heat and helping with pad life. Heck, if the Lambo gets performance rotors, that dissipate heat and weigh less, why don’t we right?
http://audirevolution.net/addons/albums/images/254154009.jpg
BOOM I saved 30lbs of not just weight but rotational weight. That’s a 15lb weight reduction EACH SIDE, while adding a huge drop in breaking temps. That’s more than some light weight rims offer and at a fraction of the cost of lightweight rims.
The added great part is way-way down the line when it comes time to replace the rotors again, you just need to order the rings. Ording the rings will save you quite a bit of money. The rotors cost a bit more due to being two piece and being that their performance rotors. Being two piece has several advantages if you really want to track the S6 you can just get an extra set of rings for the track like lots of the road race guys like to do.
I’m not a huge cosmetic guy but even these OEM rotors look underwhelming.
http://audirevolution.net/addons/albums/images/759630630.jpg
The other thing l didn’t like about the stock rotors was the fact that the rotor was just a little bigger than the pad surface needed to be. So, this resulted in my rotor having a huge lip on it from where the pads had worn away the material. It made getting the heavy OEM rotors out quite a chore.
Now putting on the JHM rotors. Very easy a straight forward job. The addition of the slotted feature that comes with the JHM rotors is not just great to help in braking performance, but I think it looks nice as well.
http://audirevolution.net/addons/albums/images/650999356.jpg
To me, it’s hard to beat adding performance while doing maintenance. Nothing is real exciting about doing a brake job, except when you know you’re dropping weight, adding performance and helping make things look just a little better at the same time. It’s a win win win.
This week we drop another 10lbs off the rolling weight of the car with the JHM rear rotors and I walk quickly through what you’re going to need to do with vag com to be able to get the rear breaks off.
Yes, you read that right. You can’t do rear breaks on these cars without the help of the computer. So, when you’re doing brakes keep that in mind. You’re in good hands here though, I post at the bottom on what you’re going to have to do to open the rear brakes.
Now on to the thread.
I did the front brakes and dropped over 30lbs between the two of them. Each side I was able to drop 15lbs with the JHM LW rotors.
With that big impact, I thought it would be time to drop a little weight from the rear rotors. Again using the JHM rear rotors.
These not only look great but they function better than the OEM units and they weigh 5lbs less each.
http://audirevolution.net/addons/albums/images/895438008.jpg
With the JHM rear rotors, you’re knocking off another 5lbs a side. For rear rotors, that’s a lot of weight. You normally don’t see that kind of weight reduction in rear rotors. The front brakes do the majority of the work so the rear brakes don’t need to be as big. Still, it’s a good area to shave weight when you can.
http://audirevolution.net/addons/albums/images/510273698.jpg
With all this weight savings I actually saved a ton of money. Usually to get these kinds of weight savings you have to get light weight rims. Since the S8 comes with 20" rims stock. It’s kinda hard to find nice light weight 20" sport rims.
Oh, and if you’ve ever wondered how much the OEM S8 rims and tires weigh.
http://audirevolution.net/addons/albums/images/242843170.jpg
That’s a lot of weight for rims and tires.
Now for the technical part of the post. Most of you might not know but you can’t just jump onto the rear rotors like you can the fronts. The rear rotors with the electronic parking break require the use of a computer to unlock and open the rear brake caliper.
If you’re a DIY’er 90% of the brake job is going to be the same the rear brakes come off easy without much fuss but when you need to open the caliper you’re going to need a computer. If you have a vag com I’ll show you what you have to do.
EASY STEP 1
Open vag com and select the “SELECT Control Module” option
http://audirevolution.net/addons/albums/images/749729030.jpg
STEP 2
Select option #53 - Parking Brake
http://audirevolution.net/addons/albums/images/665717865.jpg
STEP 3
With the Parking Brake controller open click on the - 04 Basic Settings
http://audirevolution.net/addons/albums/images/853060578.jpg
STEP 4
In Basic Settings open the drop down menu and click on Open Rear Parking Brake
http://audirevolution.net/addons/albums/images/860157509.jpg
STEP 5
You might have to still help open the piston manually. Clicking on Open Rear Parking Brake doesn’t necessarily open the piston all the way. You might have to open it to the specific spot you need to place on the pads. Now is when you would push back the piston on the caliper as far as you need and put in the pads. After the pads are on and the caliper is back on and in its place. You’re ready for the next step
STEP 6
http://audirevolution.net/addons/albums/images/37200469.jpg
That will get you all set. Some people like to do the Parking Brake Function test. I never found a need for it. That’s there if you have an issue and you’re checking the function of the system.
This walkthrough works for most cars with rear parking brake systems.
Now with all the weight lost from the JHM Rotors, you’re car will be transformed into a lighter fighter. All in all, it’s a mod worth doing. The rear rotors don’t get changed that often so this mod should last you years and years and years before you’re going to even need to think about replcement of the rings.
Getting further along in the Performance build of project V10 5.2. The next biggest step is the exhaust.
The big thing with exhausts is that you can do it wrong lose power and still sound ok. Many people have been scammed by just buying an expensive sounding stock sized Catback exhaust. Not all exhausts are created equal. The size of the exhaust can make or break the improvement factor of the exhaust. I’ve read many fancy exhaust shops and companies post about how building an exhaust isn’t some black magic. The reality of that statement is that those companies or people who don’t know how to get more power and quality out of an exhaust system don’t know how much they’re losing. In other words, some companies and or people just don’t know what they don’t know.
When it comes to exhaust systems for the Audi 5.2 V10 most of the past offerings have been a complete rip-off. The S6 5.2 exhausts have been an adapted A6 4.2 exhaust system. The Aftermarket 5.2 V10 exhaust sizes have been a complete joke and frankly have been taking advantage of people’s lack of knowledge about their cars.
There was a company that offered an X pipe for the S8 V10. Frist off the size was too small for real performance but let’s forget about that for a second. The biggest scam here is, that the S8 V10 5.2 exhaust system already has an X pipe. What a rip off that was.
So, the next question is other than sound do we really want an exhaust system for our cars? Well, we bought V10 cars for fun and performance. A real performance exhaust doesn’t have to be loud and obnoxious. My exhaust system is 3" and I’ll put up video of the in cabin noise, you hear more road noise than exhaust tone. You’d almost not know there’s an exhaust. The truth be told 2.75" is perfect for these cars, it adds that euro tone and makes in cabin noise more controllable. It’s also good for about 200hp over what the stock exhaust system flows.
One last thing to think about before I get too far into my post. Adding things like air filters help the motor breath better on the intake side. It allows easy flow of the outside air into the intake manifold. We all know that the motor pulls in outside air when the piston is on the intake stroke where it pulls in air by creating a void. But did you know that the headers and Catback actually pull in and act in pulling in more air than the motor itself?
Now onto the actual post. Knowing how much hp can be gained I decided to do some testing and take it one step at a time to see just how much more power I would be able to pull out of the V10 by just messing with the exhaust.
Note- the S8 exhaust is where the bulk of the power gain is over the S6. The S6 will actually gain more power than the S8 as the S8 exhaust isn’t as restrictive. While the S8 exhaust is still restrictive the S6 exhaust is just terrible stock.
We have a thread dedicated to this but if you haven’t seen it before. The S6 exhaust is on the bottom. Look at how the piping isn’t smooth and its all crushed.
http://audirevolution.net/addons/albums/images/619428370.jpg
The other thing you’ll notice is that the S8 has a valved exhaust where you can have both tips flowing air vs just one.
http://audirevolution.net/addons/albums/images/146726730.jpg
So, for testing, I did what we all would have done.
http://audirevolution.net/addons/albums/images/984732047.jpg
I welded the exhaust valve open.
I did notice a little more noise but it was only in the higher rpm’s. A little more noise at idle but not enough to consider this a mod. Start up was obviously a little louder as the motor goes through its rev range warm up cycle.
After that modification didn’t do much I just said the heck with it. lets just take off the old system and build a new one.
Here is what the old system looked like on the car.
So, it went from this.
http://audirevolution.net/addons/albums/images/438409113.jpg
To this.
http://audirevolution.net/addons/albums/images/567260061.jpg
http://audirevolution.net/addons/albums/images/716982204.jpg
http://audirevolution.net/addons/albums/images/140817017.jpg
The difference was tremendous. Sound, performance, and throttle response all came into play and all worked much better with each other. These cars react really well to a proper exhaust as I mentioned the S6 will react even more so, While I did feel a gain it was clearer now that the ECU was now working overtime to hold back even more power.
These cars are De-tuned from the factory to hold back a lot of the V10 power. That became clearer after adding the exhaust. I kinda felt it each time I added something new to the car like rotors or intake spacers but adding the exhaust put the car over the top. I could now really tell the Audi De-tuned computers were working overtime.
Thankfully, the next modification was the best for last. The JHM tune. Stay tuned that’s coming up next.
A video would help right? Sorry, here it is.
http://audirevolution.net/videos/173/s8-v10-s6-v10-performance-exhaust
I have some in car video if anyone is interested.
http://audirevolution.net/videos/185/worlds-fastest-aud-5.2-s6-s8-v10
Also, there are some S6 JHM tuned results as well. We’ll have to wait for them to post their results. But right now, as it stands, the worlds fastest S6 5.2 V10 and S8 5.2 V10 are JHM Tuned.
I’ll make a post later talking about my thoughts on the tune. I just wanted to get this up for everyone to see.
It’s been a few min since my last update so I wanted to get back with an update.
I’ll post a quick update and then like to get some feedback from the great guys on here about where to take the car direction wise.
Here is where I basically left off.
For those of you who don’t have the JHM tune but have been reading about it. The JHM tune can only be explained by simply saying there is in my opinion and based off performance figures, there is no equal. Anything less than the JHM tune for your V10 5.2 is just a waste of money. This has been talked about over and over so I’ll let the performance speak for itself.
My thoughts on the JHM tune are as follows. Overall, if you love the V10 sooner or later you will come to terms that something is missing and that something, is the real power of the V10. You can tell the OEM tune is holding the car back with the JHM tune your 5.2 V10 is unleashed. I can’t express enough how no other tune out there will offer what the JHM tune does.
Let’s break it down like this.
Throttle response.
OEM - lazy there is a bit of a delay it’s never quite crisp like you would like to see. It’s definitely a detuned luxury feel.
JHM - The best way to say it is crisp. The throttle is in sync with our throttle placement. The delay is removed and now the full power of the V10 can be managed fully by the throttle.
Power & Delivery
OEM - Down low the car sluggish. While the motor still makes power its buffered enough to keep the car from really getting off the line or accelerating quickly at low speeds. but wakes up in the upper rpm range to give you a nice constant smooth acceleration.
JHM - This ties into the throttle response a bit but zero restriction down low. There is an abundance of power now available at lower throttle input. The lower part of the rev range that was once powerless on the OEM tune now has a full load of power to deliver. This is all of the TQ this nice size 5.2 can make so down low this isn’t just a little difference it’s a marked improvement so much so that you’ll find yourself needing to use less throttle than before to get the car up to speed. In the upper rpm’s where the car really shined last time now the car has a more confident full and power feel where you can really keep increasing the cars acceleration with every inch of the throttle input.
From a data log standpoint, you can really see what the JHM tune is doing. You can see JHM has turned off the lower closing of the port flaps. Closing, of the flaps in the OEM tune, kills down low power but there is more. When you give the car more throttle you see the throttle plate move in direct line with the ignition timing, the fuel and most importantly the camshafts. The combination of all this is something that’s clearly not be offered in other tunes for the 5.2 V10.
Saftey
OEM - tune offers a wide range of safe items that turn on your warning lights on the dash
JHM - I know this isn’t really sexy but there are lots of unique little issues that our cars have and the JHM tune makes sure to put a spotlight on those issues sooner than later with error triggers that pop up sooner than later. The power is great but the ability to keep the car safer is even better.
Fuel mileage
OEM - I was seeing about 19 on average
JHM - I was seeing about ~23 on average. Keep in mind this also included the cat back exhaust so I figure the tune is good for about 2 or 3. Some guys are seeing more.
Exhaust note.
OEM - Nice but still subdued
JHM - First start of the car on the JHM tune and you know something good is about to happen. In the middle and higher rev ranges, you can really hear the car breathing better and the exhaust tone reflects it. Really helps give the car that more exotic sound
Overall thoughts.
If you’re a V10 5.2 owner this is a must have. The JHM tune really ties in every aspect of the V10s potential. This is what you expected the V10 to be and to offer. The performance isn’t even matched by doing anything else. When you look at the acceleration times of the past tune offerings people were not able to be much faster than stock 0-60 and the 1/4 mile results were sad. Now you have 12-second capable car with the JHM tune before the JHM tune the best tune offerings for the 5.2 V10 could barely get into the 13-second range.
That is my thought on the JHM tune. A worth the money get and something that will really help make you love the 5.2 V10 all over again.
Well, the choice seems clear now. I think it makes sense for me to pull myself off the beta list for now for the JHM supercharger. I wanted to get my car from the 12s into the 11s by the end of this year and the JHM supercharger kit would have put me well into the 11-second range.
The good news is that me taking myself off the JHM supercharger list opens up a spot for another Audirevolution S6 guy to get on the JHM beta supercharger list. So tell your friends ;D
I think it makes more sense for me to let someone else take my spot and since the JHM beta supercharger program only lets in so many customers and the V10 program is growing with so much excitement, I want to see the platform continue to grow.
Here is where my car is at. Last year after blasting the low 13second pass I felt great but really felt like the car was still choked off somehow. luckily the JHM tune popped up a lean code for the car that led me on a chase to find out what the issue was. I wanted to slowly learn what I could so, I took my time and did as many logs as I could and spent as much time as I could to learn more about the car and how each system worked.
I knew it was going to be injector related as let’s face it. Everyone one of us has had to replace an injector or more. we are starting to see just how big of an issue injectors are on our cars. I actually talked about this here in this post.
http://audirevolution.net/forum/index.php?topic=3950.msg114965#msg114965
So, what I found out was that my injectors were definitely holding the car back. I asked a local friend (Justincredible) to come by and help get as much data as I can. The issue was definitely getting worse and we spotted an anomaly that could have been in part why some in the past have had damaged cats that required replacement. Seems one of my injectors was actually leaking. It took a long time to find this and figure it out. The cost of all the logging and time to see how bad injectors effect the car and what can happen when you drive around with a leaking injector. It took out my primary 02 on bank 4. The bad news is if you want to replace that 02 you need to drop the motor.
After knowing that headers are the obvious choice. Now I’ll start gearing up for dropping the motor and building the headers for the car. The entire process will take several months and I would like to see the car back on the road just before the track season ends in November.
Before we get into that I think my next post should be about the injectors and what we learned from testing. I’ll tell you what. If you haven’t had your injectors tested or replaced. It’s not a bad idea to consider doing so.
I got with JHM and they’re testing injectors at 110bar, cleaning the injectors and testing them again at 110bar. That is so important, as I’ve not seen any other company even those that offer cleaning services actually testing them at 110bar. The other injector cleaning and testing companies only test at about 5 bar some might get up to maybe 10 bar but my injectors didn’t even show a leak until 30 bar. So conventional testing methods outside of what JHM is doing wouldn’t have even shown a leak and the leak is what caused the damage to my 02 sensor leading to me now needing to pull the motor.
My next post will be the testing results I got back from JHM and some pictures of the injectors after I removed them.
Those of us that are going to be pulling out our own injectors take note. You can get the injectors to come out but after say, 100,000 miles they tend to get a little used to being in one spot. Take into consideration years and years of heat and extreme heat cycles.
My tips for removal.
To remove the injectors plan on lots of time and patience. Spray the outer edge of the seal kit area with a liberal amount of penetration lube. The injector removal tool did more damage than just using a few hand tools and some finesse. I used a combination of vibration on the hard fuel rail to loosen any available bond. From there I used a long pry bar with some good old fashion common sense. Take your time use vibration, penetration lube, a rocking motion, and leverage. The injectors are actually spraying as part of the compression cycle and need to withstand the pressure of combustion in the chamber. Keep that in mind, that is how sealed the injectors are and how tight the fit is going to be.
Here you can see I pulled the fuel rail off. You can see the cylinder 6 injector O-ring stayed in the rail (blue) you can see only injectors 8 and 10 were pulled up and removed leaving injector 6,7 and 9 to be pulled.
http://audirevolution.net/addons/albums/images/11801051.jpg
Here is a picture of the injector without the seal kit installed and without the rubber O-ring.
http://audirevolution.net/addons/albums/images/893119960.jpg
This next picture below is what I have been saying for years on why I don’t like using walnut shell blasting for doing carbon cleans. Keep in mind a professional that uses this walnut shell technique might have better control or a better overall process but for me and the others I’ve seen that do walnut shell you risk having this happen.
http://audirevolution.net/addons/albums/images/210055872.png
What you’re seeing here is walnut shell bits in the injector seal sleeve and there is a clear sign of some of the shells getting past the guard. Now I see it as literally impossible for the shells to penetrate the actual combustion seal and make their way into the cylinder but for me, I don’t like seeing walnut shells that close to my cylinders.
So let’s move on to the actual cleaning and testing results.
Honestly guys. I don’t even know how my car was as fast as it was. I know the JHM tune kept the car safe and allowed it to be as fast as it was but when you see the condition of the injectors and their results you will see what I’m talking about.
Keep in mind the target for 110 bar is 1000CC So the numbers you want to see are 1000. Here are the before.
Before (110 Bar)
10)267.07 ****
9) 937.95
8) 522.89 **
7) 937.07
6) 851.80 Leak
5) 937.95
4) 827.43
3) 669.07
2) 364.52 *****
  1. 937.95
Not keep in mind #6 had a leak and we only found that it was leaking after 30bar. So conventional tests would have missed this.
Here are the after.
After (110 Bar)
950.15
974.53
998.92
1047.69
1023.31
970.78
1023.31
Bad
1035.50
I can post more about this in a little bit. I have a prior engagement that I need to go to so, I’ll have to leave this post and come back to it when I have more time.
Before I forget. I pulled my injectors and a friend’s injectors out of his S8. We did the same test and cleaning on his injectors. His injectors were in much better shape than mine.
Before (110 Bar)
974.53
767.25
767.25
755.05
840.41
559.96 **
486.80 ***
572.15 **
913.57
913.57
After
After (110 Bar)
998.92
962.34
950.15
925.76
950.15
1011.11
998.92
937.95
974.53
937.95
As you can see even on his car some of the injectors were almost down by 50% that’s not good. Again with this test, the higher actual operational pressure tests showed more than the lower tests. The tests were actually performed at 110bar 30bar and the standard 5bar.
I know you posted this in the S6 section originally but this is a great read. Thanks for all your work on this.
Forgot about this… We should get the data on audi/VW use from EFT over the next few days, but I believe the fuel system component has proven to eliminate and prevent future carbon buildup. I have units in hand now. May need to get another one for you and Jimmy to test alongside my car(s).
I don’t know what exactly your talking about here but the fuel system has little to nothing to do with the actual carbon build up. The build up in the intake and intake valves comes from the crank case PVC system and oil mist getting in the intake track at low speed idle conditions where the oil separator isn’t working at peak efficiency.
On the FSI cars. The injectors are post intake valve so much unlike older cars you don’t get fuel wash keeping the valves clean. To combat and fix this carbon issue Audi is now using a pre valve LP injection system to once again fuel wash the valves.
If there was a fuel component issue with carbon you would see the exhaust valves with carbon build up and you don’t see that.
Love it CV! This stuff makes me want to change professions
I’m so late seeing this lol. Sorry, I’m almost never in the S8 forum. Yeah, I know. Apparently they resolved it through optimized combustion. But that’s me, a layman, explaining lol. The engineer(s) could do a much better job. I can shoot you the data on hand if you PM me your contact details.
optimized combustion still will not help a poorly designed PCV system. This is solely upon the vent engineers shoulders to design an appropriate crankcase breathing system for the engine.
The combustion engineer just has to then deal with the oil mass entering the chamber and ruining his perfect combustion model!
