REVOLUTIONARY RESULTS - Dragstrip database update notification thread
Your stock Avant would be a 1/2 second quicker and trap at 2-4 mph more.
The tuned for altitude is a shit excuse. The ecu has altitude correction built in. So who ever gave you that excuse was lied to or making up stuff because there car was running stock times.
Other then that good runs for everyone else.
Jhm’s s4 runs low 11s at 125-130 mph and I don’t think it was even running that night. You sure that was it? They had a b7 a4 there and a customers white b7 s4 tiptronic with a stage 1 supercharger were also there.
what did you run stock? I think you’d be surprised how crap the 91 octane gas is.
admittedly the time isn’t great, but nobody really ran great times for a start…pretty much everyone was about 2-3 tenths/mph slower than we thought they’d be (from what we’ve seen)
15.5@90 for the B8 A4 with mods? Did the mods include a 1000lbs worth of audio gear in the trunk?
I never ran stock.
It’s an A4 not an S4. Trapping 90 shouldn’t be shocking for a car on 91
91 sucks more then some people know. Not sure what the by A4 runs stock but you would think a modified one would be quicker then that.
I never ran stock.
added infinkc B8 S4 Manual E85+pump 100 octane tune (APR) S2; 12.26 @ 113.43
also added a few of the miscellaneous times posted on other forums, mostly B8 S4 times, none were records
p.s. we now have 131 entries…for B8 S4s alone! Incredible.
Many are duplicated, in that when guys go and break their record they are added again, or change mods etc. Still…wow. For perspective, there are only 34 RS4 times.
Hello all (saki)
Here’s my slip-
Motor: Stock, except for some Zircotec heat shielding on the manifold, like JHM does for the V8.
Wheels: Vorsteiner VFF-101 Wheels (~12kg ea), with 275/30R20 Michelin PSS
Fuel: Shell V-Power 98RON (3/4 full tank)
No A/C, no T/C, spare wheel removed.
http://i61.tinypic.com/1zev4ex.jpg
Hello all (saki)
Here’s my slip-
good stuff. I can wait till you go back to the track before adding you (if you’d like) so that you can get your 13.xxx first.
You should be just coming into the good weather for racing down there, so hopefully you get it done soon!
