There seems to be a common problem with the Audi S6 (and many other cars using the ZF 6hp26 and 6hp26a transmission). It has been called the ZF Lurch, and is described in the following two sceanarios:
[i][b]Variant 1 : The Lurch we experience occurs when you bring the car to a halt in a smooth manner by braking very gently and letting the car come very smoothly to rest. Just before the car has come to a complete rest a little lurch like somebody has gently nudged the car occurs. It feels like a gear is being engaged or disengaged just before coming to rest. This can vary in intensity from a very slight nudge to a powerful jump that rocks the car.
Variant 2 : In addition, when you slow very gently to a creeping halt without actually stopping and then gently try to accelerate - there is a slight hesitation when the engine revs higher, then the gearbox engages the drive wheels with a jolt. This varies from a harsh jolt to snatchy.[/b][/i]
If you google “ZF lurch”, and there are entire websites dedicated to it http://www.thelurch.com/lurching_zf_transmission.htm (not a good sign, as there did not seem to be a clear resolution)
Looks like people are trying all kinds of things…TCU update, transmission oil flush using specific oils (e.g. ZF Lifeguard6 http://www.xoutpost.com/822704-post85.html), rebuilt valve body http://www.xoutpost.com/872353-post12.html, etc. Looks like we are going to have to start another thread for this problem. At least we arent alone on this one, as BMW and Jaguar seem to be effected too.
If you have this problem in your v10 S6, (or Audi A6), then please post here so we can track the issue, and work on solutions. We need to know the following:
- What year and model is your car?
 - Does your car experience Variant 1, Variant 2, or both
 - Does it happen in certain conditions, and not in others (e.g. when driving when car is cold, when using sport mode, etc)
 - Has the dealer done any fixes for the issue? Have they worked?
 - Have you done any other updates or changes that resolved (partially or fully) the issue?
 - Any other pertinent details
